![]() | Home > In Car Electronics > Where to mount CB radio - Puma dash? |
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 ![]() ![]() ![]() |
Interesting that you ask... I'm in the same boat...
I thought about under the seat and then getting one of those mic's with the display in, but it doesn't work with my CB... I did quite like the idea of it being overhead as it's out of the way and not too noticeable, but, i've gone off that idea... I'm currently thinking about building a raised cubby box with it all integrated in there, CB, amp, fuse box etc.... but not sure I will watch this thread with interest |
This is where I have mine:
![]() Click image to enlarge Required a little bit of trimming but not much and it looks like it was supposed to fit there. Wiring was easy, power from the back of the lighter socket and antenna through the dash and up the A pillar. Mic sits on the shelf to the left of the steering wheel when I'm not using it. The radio is attached in with sticky back Velcro. |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
Is this any use...?
http://www.mudstuff.co.uk/products/mud-stu...mount.html Cheers Simon Edit: oops, I see you already discounted this... ![]() On mine, I've fitted the CB on the inside of the cubby box, on the sloping front section. It doesn't take too much room and is easy to access. Last edited by couplands on 23rd May 2016 8:34am. Edited 1 time in total |
gabe3105 Member Since: 25 May 2015 Location: Grimsby Posts: 237 ![]() ![]() |
or this......?
http://www.fcx.co.uk/#!product/prd1/2580675521/defender-steel-'radio'-cubby-box |
^^^^^ Thank you
![]() ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2660 ![]() ![]() ![]() |
I've mounted my Midlands unit on the passenger side, where the handbrake would be.
It's out of the way enough that my wife's legs are not impeded, but still close enough for me to fiddle. I've mounted the mike on the panel in front of the transfer case lever, so it's handy when off-road. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Use both the FCX & Mud methods both are great
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Cupboard - I can't see your picture !?
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
Or ...Corsetti Roof-Consolle
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge http://www.davidecorsetti.com/prodotti.php...p;id_cat3= Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
That is very neat.
dantastic Member Since: 04 May 2010 Location: London Posts: 367 ![]() ![]() |
I like that roof console actually. Any idea the price of it?
On second thought tho, how is it having the mic wire dangling covering the view in the rear view mirror the whole time..? I like it but I wonder is it practical. |
![]() I don't know the price in Italy.... But ... http://www.lrsoffroad.co.uk/roof-console-f...-roof.html There is also this : http://zmode.it/prodotto/consolle-da-tetto-defender-90110/
The mic wire is not a problem ! ![]() http://www.consoles.com.au/Rover_LandDefender_deep.htm Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Charles Member Since: 04 Sep 2013 Location: Dudelange Posts: 16 ![]() ![]() ![]() |
Hi
Have a look here http://acc16.com/consoledefenderm/console-de-toit-defender.pdf Best Regards Charles |
Hmm. Sorry! Take 2: ![]() Click image to enlarge |
