![]() | Home > Technical > Rear view mirror |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3818 ![]() ![]() |
Hello
Does this help keep going down until you see the bracket that holds the mirror http://www.defender2.net/forum/topic43275-135.html Given yours was a van maybe you have not got this behind the headlining as you would have never had a mirror? |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333 ![]() ![]() |
lots of help. I have that exact fitting but have no idea that I would need riv nuts as there were none fitted. The mirror just has a spring loaded clip on it.
Were the tools an ebay purchase? I need a rivi nut tool for some other tasks |
There is a plate that gets screwed onto the bracket you have when the rivnuts are fitted then the mirror fits to the plate. Ray
Easily learn to use side mirrors
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 ![]() ![]() ![]() |
It's a defender, anything over 40mph and the side and rearview mirrors just vibrate like a rampant rabbit...so you wont be able to see anything anyway...
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
Must be a deluxe version!
My rear view mirror does that, but my wing mirrors are fine at full speed ahead? and I've got the large Mud ones? |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 602 ![]() ![]() ![]() |
Removed my rear view mirror today, what a difference being able to see through the entire windscreen not have a lump of plastic half way down it.
Will look for a stick on one tomorrow to place at the top of the screen. |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
I got rid of mine long ago.
Was right in my line of sight and had to keep ducking underneath it to see across junctions. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17682 ![]() ![]() ![]() |
Bear in mind that the interior mirror is a legal requirement on vehicles manufactured from 1978 unless you cannot see anything in it due to the configuration of the body. If you have a full-height bulkhead, have plated over the rear window, or (like me) have a solid flap on an IW canopy, you don't need a mirror, but if you have a rear window and can see out of it from the driver's seat, the law says you must have an interior mirror.
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
Yet another advantage (of a very long list) to being someone who is 'closer to the ground'. Like a lower centre of gravity and finding normal legroom seats perfectly suitable.... ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Interesting, I have a full height dog guard permanently with rear bench seat squab attached to it (sounds weird but looks better than it sounds trust me!) so would that count as you can't see anything past it?
Haha true, I'll remind you of that next time you cant reach something ![]() ![]() Self confessed mileage hunter ![]() |
The major downside to being tall and manly (pfff) is that you smack your head on low beams, interior lights, raised cupboard doors that your other half opens and doesn't tell you, your back goes if you do anything in the kitchen as all the surfaces / sinks are designed for a woman, and its further to fall, air is thinner and if you get the tube, you can but close your eyes because to do anything else results in women believing your looking down their top...whether they put them there first or not!
Picked up a suction mount one from Halfords, sits at the very top of the screen, is pretty much identical shape to the original, has dip function and does not vibrate at high speed.
Can now see out of the windscreen perfectly. When I place the original in front you really get a sense of how unnecessary the original placement is (with the exception of the sun visors now obscuring most of the mirror when in use). Now need to find a way to cap off the original bracket? Are there versions with no mirror from the factory, ie van types, in which case what do they have in place? Also would like to cover the suction point on the windscreen with some of that dotty film that goes around modern car glass if anyone has a lead on that. |
