Home > Technical > Rear view mirror
Welkman
Rear view mirror
Hi,
Just trying to fit a rear view mirror to my 110 van as I have popped on a new back door. I have the metal pressing in the window frame but this does not seem to be enough to secure the mirror on its own. Does it need a shim as well? Im sure I must be missing something.
Cheers.
Post #533849 22nd May 2016 10:14pm
Stacey007
Hello
Does this help keep going down until you see the bracket that holds the mirror
http://www.defender2.net/forum/topic43275-135.html
Given yours was a van maybe you have not got this behind the headlining as you would have never had a mirror?
Post #533856 22nd May 2016 10:27pm
Welkman
lots of help. I have that exact fitting but have no idea that I would need riv nuts as there were none fitted. The mirror just has a spring loaded clip on it.
Were the tools an ebay purchase?
I need a rivi nut tool for some other tasks
Post #533861 22nd May 2016 10:41pm
mk1collector
There is a plate that gets screwed onto the bracket you have when the rivnuts are fitted then the mirror fits to the plate. Ray
My build thread
Post #533868 22nd May 2016 11:09pm
jimbob7
Easily learn to use side mirrors Evil or Very Mad !!!!!What do you think van/lorry drivers use?? Pov.spec,ftw. 2006, 110,TD5.
Post #533969 23rd May 2016 1:34pm
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
It's a defender, anything over 40mph and the side and rearview mirrors just vibrate like a rampant rabbit...so you wont be able to see anything anyway...
Post #534087 23rd May 2016 8:32pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Must be a deluxe version!
Post #534094 23rd May 2016 8:45pm
Cupboard
My rear view mirror does that, but my wing mirrors are fine at full speed ahead? and I've got the large Mud ones?
Post #534154 23rd May 2016 10:40pm
Stiff1
Removed my rear view mirror today, what a difference being able to see through the entire windscreen not have a lump of plastic half way down it.
Will look for a stick on one tomorrow to place at the top of the screen.
Post #534171 24th May 2016 12:17am
shaggydog
I got rid of mine long ago.
Was right in my line of sight and had to keep ducking underneath it to see across junctions. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #534267 24th May 2016 12:52pm
Bear in mind that the interior mirror is a legal requirement on vehicles manufactured from 1978 unless you cannot see anything in it due to the configuration of the body. If you have a full-height bulkhead, have plated over the rear window, or (like me) have a solid flap on an IW canopy, you don't need a mirror, but if you have a rear window and can see out of it from the driver's seat, the law says you must have an interior mirror.
Post #534293 24th May 2016 3:30pm
Grenadier
Yet another advantage (of a very long list) to being someone who is 'closer to the ground'. Like a lower centre of gravity and finding normal legroom seats perfectly suitable.... Whistle Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #534300 24th May 2016 4:04pm
shaggydog
Interesting, I have a full height dog guard permanently with rear bench seat squab attached to it (sounds weird but looks better than it sounds trust me!) so would that count as you can't see anything past it?
Haha true, I'll remind you of that next time you cant reach something Whistle Laughing Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #534538 25th May 2016 1:06pm
LoveTheMud
The major downside to being tall and manly (pfff) is that you smack your head on low beams, interior lights, raised cupboard doors that your other half opens and doesn't tell you, your back goes if you do anything in the kitchen as all the surfaces / sinks are designed for a woman, and its further to fall, air is thinner and if you get the tube, you can but close your eyes because to do anything else results in women believing your looking down their top...whether they put them there first or not! Rolling with laughter
Post #534557 25th May 2016 2:08pm
Stiff1
Picked up a suction mount one from Halfords, sits at the very top of the screen, is pretty much identical shape to the original, has dip function and does not vibrate at high speed.
Can now see out of the windscreen perfectly. When I place the original in front you really get a sense of how unnecessary the original placement is (with the exception of the sun visors now obscuring most of the mirror when in use).
Now need to find a way to cap off the original bracket? Are there versions with no mirror from the factory, ie van types, in which case what do they have in place?
Also would like to cover the suction point on the windscreen with some of that dotty film that goes around modern car glass if anyone has a lead on that.
Post #534598 25th May 2016 4:47pm
