Home > Maintenance & Modifications > Warn 9.5 xp from a Disco 3 kit install question
dshickle
2007 Defender 110 Puma 2.4 CSW Galway Green
Has anyone tried to fit a Warn 9.5 xp from a Disco 3 kit to a Defender?
I have such a Winch from a previous D3 i owned.
The challenge is the control plug for the remote is separate from the solenoid pack. It has has a couple of wires which are connected to the D3 fuse box and a small solenoid. I guess these are switched somehow to enable the remote to operate only when the ignition is on and engine is running.
Can't seem to find a installation guide online (i've looked at the Warn site - no real clues) - The D3 installation manual for the kit does not make it obvious.
Just trying to identify where these wired should go.
I'm not sure I'm making myself clear(No change there then) on the wires i'm trying to describe.
Any advice much appreciated.
David Disovery 3 TDV6 SE
Defender 90 XS 2.4
Defender 110 S D250 (MY22)
Post #1421 20th Feb 2008 10:38pm
AndrewS
It should bea simple job. Have you contacted 10forcash on the D3 site Question
Post #1425 21st Feb 2008 8:28am
dshickle
10forCash - fantastic help. Very Happy
Once I have it fully figured out - i'll post something here in case it is of benefit to anyone else.
Defender 90 XS 2.4
Post #1440 22nd Feb 2008 9:35pm
DAM_DEF
Sorry to come back on a very old post did you conclude installing the Warn 9.5 xp I am facing the same dilemma no documentation to follow.
Post #533180 20th May 2016 12:42pm
John Fair
United Kingdom 2013 Defender 110 Puma 2.2 USW Santorini Black
The standard control plug completes a circuit to a remote battery isolator on the D3. ie there is no main battery live at the solenoid if the controller is unplugged. Personally I would replace the solenoid box with an Albright as its a smaller neater package and simply put a good old fashioned manual battery isolator in the main cable. Hope this helps.
Post #533609 22nd May 2016 6:22am
DAM_DEF
Thanks for the reply, agree the Albright would be much neater and simpler will upgrade at some point so far making progress only the blue controller cable is a mystery now, rest up and running Very Happy. Any clue on the blue wire?
Post #533614 22nd May 2016 7:00am
John Fair
Unfortunately no I cannot recall and I no longer have the vehicle to go and look. They are a relatively simple system so what do you have wired to where? It may come back to me. There is a winch in, winch out, and a basic ring circuit that completes to turn on the remote battery isolator ie the hand held completes the circuit constantly when you plug in.
Post #533624 22nd May 2016 7:50am
John Fair
You should have a remote isolator a bit like this or a variant of it.
Post #533628 22nd May 2016 7:56am
DAM_DEF
I absolutely have that solenoid and I have taken the white constant 12v live via this to the controller and on my set up this is all working fine I just have an obsolete blue cable, warn list as thermal cut out..... I can live with it being detached more curiosity of correct usage. Thanks so much for the response.
Post #533639 22nd May 2016 8:25am
John Fair
I don't recall ever having a thermal cut out wire. If it all works I should just ignore it. It does work??? i do recall the origional wiring had to many wires and clutter. Sorry I can't recall more. It may well come back to me. Again I would just say change out to an Albright. It really is a better package and your in there now anyway.
Post #533644 22nd May 2016 8:43am
walfy
I've fitted a 9.5 xp from a D4 to my 110. Had to get the remote socket removed and connected to the solonoid box. Made a metal bridge over the drum to hold the control box. I had to extend the wiring from winch to battery.
Can take pics if required 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #533669 22nd May 2016 10:47am
