Home > Puma (Tdci) > 2.2 puma clutch replacement cost.
S.D.
Can anyone tell me a ball park figure for having a new clutch supplied and fitted at an independent? Also, is there anything else worth doing at the same time that this is being done?
Thanks.
Post #533173 20th May 2016 1:15pm
agentmulder
Kuwait
I'm in NZ so keep in mind while some things are cheap over here, LR parts and mechanics aren't.
I had issues with my slave cylinder with a 2.4 around the 60,000Mi, upon opening it up the mechanic (independent) showed me the play and wear in the clutch, there was not much past another 10,000 in it, so it and the bearing were replaced at the same time.
I figure 2.2 should be the same (?)
So, depending on your age you might want to replace the slave cylinder while you're in there. By all accounts the ol' 'and then my clutch pedal just stayed on the floor!' is a common occurrence.
I opted for the 'more' OEM parts (unsure if they are actual LR), but they did cost more, total incl. work was around £600.
I justify the cost by doing most of my other repairs myself, it's when things get heavy, awkward and unknown that I opt in to the shop. Solved the bowel problem, working on the consonants...
Post #533573 21st May 2016 10:54pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
I should verify the link between gearbox and transfertbox.
If not OK seems the right moment to correct it.
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #533789 22nd May 2016 7:47pm
