Home > Puma (Tdci) > Puma double DIN dash
Page 3 of 3 <123
OCD
I've recently fitted the Pioneer AVIC-F960 which works with the Apple Car Play. I used it with the iPhone once or twice but if the phone drops signal it becomes useless as a satnav. Car Play just seems a bit gimicky as most units will do most of the things that it can do.
I just ran a usb cable from the back of the unit to under the steering wheel & plugged in an ipod for my downloaded music, and use the Pioneer for everything else...
Post #401688 24th Feb 2015 2:01pm
thatsilverpuma
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
Hi Guys, I'm from South Africa as you can see, yes yes Zumaland...anyway I've been battling to find the double din fascia kit with the switch plate that doesn't have that huge hole in it, for the life of me I can't understand how that is the most produced version of the kit. Anyway I see above that the manufacturer is based in Germany, could someone please tell me what the companies name is or direct me to a website of a company that stocks the fascia kits like the one above. I'd prefer to find one in Matt Black if possible, also our Defenders generally don't have heated seats (its never that cold here) so I'd need to find a kit that doesn't have the holes for the dial on the left.
If someone could help me out with this that would be AMAZING!!! I've been searching for years...literally.
Lekker thanks guys!
Post #532998 19th May 2016 5:34pm
mcma1
Did you try Twisted? I have seen a few off their conversions without the large hole. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #533041 19th May 2016 7:53pm
Stiff1
You just cut it off and file smooth.
Alternatively mount the relocated switches on your cubby and you don't need to cut up the dash, that seems to be becoming the preferred method.
Post #533154 20th May 2016 10:16am
Spectre
A paint shop could fill it with filler, smooth and repaint the piece.
To be honest I have the switch plate and now thinking about it if I could have it done again it would be integrating the switches to the cubby box, looks cleaner and OEM.
Post #533318 21st May 2016 12:44am
thatsilverpuma
That does make a lot more sense, does anyone have a picture of the buttons mounted on the cubby box? I did Google it with no luck.
Also I did email Twisted about their fascia, but I haven't got a reply, so I don't think they're too interested.
Post #534246 24th May 2016 10:31am
JOW240725
From memory the Twisted double din was over £500. You're probably better off getting a double din fascia for £230 and fitting the other switches in the cubby? James
Instagram @suffolk_rovers
Post #534279 24th May 2016 12:39pm
Stiff1
Have a look at mcma1's Corris 110 thread above, he has images showing the whole install.
Post #534424 24th May 2016 11:39pm
Page 3 of 3 <123
