Home > Puma (Tdci) > 12v feed behind R/S rear speaker panel purple +ve, black -v |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Is the unused 12v feed plug behind the R/S rear speaker panel (purple +ve, black -ve) a fused supply and if so where is the fuse located?
Cheers. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
16th Jan 2011 3:05pm |
Gotcha, I'll go and have a look. Mine is live all the time so looks as though the fuse is already in.
Thanks for that Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
16th Jan 2011 3:17pm |
Found it.
Thanks again. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
16th Jan 2011 3:34pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8025 |
so was mine. i think on the older vehicles 07/08 the fuse needed to be added. 09 onwards they seem to already have it fitted. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
16th Jan 2011 3:36pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
early 08 Fuse was in
Ive not come across one even an 07 without a fuse...although it could be a model thing (it was an XS as is mine) Mike |
16th Jan 2011 5:37pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2658 |
Mine was a 57 90 XS. That didn't have the fuse fitted.
But it did have a leak that LR couldn't fix 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
16th Jan 2011 5:42pm |
There's always one! Mike |
16th Jan 2011 5:43pm |
I'm sure others have leaks 110 D250 SE HT
16th Jan 2011 5:45pm |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 |
What do you guys wana do with this 12 V supply? What is the fuse rated at? Dont wana burn the wire before the fuse fails. Would be great to get a 12 V supply that's already wired up!
16th Jan 2011 6:24pm |
I fitted a cigarette style receiver in the speaker panel. I then used this for running my coolbox and I had some exterior lights on an extension lead. 110 D250 SE HT
16th Jan 2011 6:30pm |
One should be carefull. I've heard of people melting wires pulling 4 amps on fridges where the wires just isn't thick enough. I'm planning a DIY dual battery system. I installed one before in a cruiser. Taking 16mm^2 wires to the back to run my fridge (pulling bour 40 wat max), and everything else. That extra 12V for running small stuff though will be sweet!
16th Jan 2011 6:38pm |
Coolbox not fridge.
On my D3 I ran some big cables to the rear to an aux fuse box to run the fridge. 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
16th Jan 2011 6:57pm |
i have run a fridge off mine, no problems to date.
TJ101s 07 didn't have a fuse fitted. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
16th Jan 2011 7:22pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
My 57 is fused already.
It's a good supply for a rear work light. I assumed it was intended for that although a lot of people add aux sockets. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
18th Jan 2011 2:52pm |
