Home > Technical > Rev counter and temp gauge not working - loose connection
tomm
United Kingdom 2012 Defender 110 Puma 2.2 USW Zermatt Silver
Hi all. Apologies if this has been answered. I did see a few threads but couldn't get a fix. I think it's because I'm describing the issue on a 2012 2.2
Anyway here goes. Last week the tacho started hitting zero the. Bouncing back to normal. As though there was a loose connection then eventually after about an hour or so I guess the connection rattled loose and it just stayed on zero and the temp gauge at the highest point.
Other threads have pointed to the connections below the drivers seat but for the life of me I can't find this. Maybe it's because there is a bunch of connections below here on earlier models?
Any help massively appreciated.
Cheers!
Tom
Post #532450 17th May 2016 6:54pm
nickhodgson
I am pretty sure that my Puma does not have any earth in the box under the drivers seat. There are some relays there that can cause bother but its usually the car cutting out or something.
Where do the Rev Counter and Temp Gauge signals come from before the cluster? The ECU?
Have you removed your cluster recently as the connector is somewhat special and can be fitted incorrectly? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #532650 18th May 2016 1:57pm
There is an earth stud in the drivers seatbox, it also is a mounting point for some of the fuse box tabs. (Metal)
More than likely loose connector on the rear of the dial cluster, they've been known to become loose even without touching it.
It'd also be worth disconnecting the battery before touching it and leaving it disconnected for a while.
Then see if the issue is cured.
Thumbs Up
Post #532652 18th May 2016 2:03pm
tomm
Thanks will give them both a go
Post #532654 18th May 2016 2:05pm
tomm
So finally got around to pulling the cluster off. It un plugs it and is one solid unit. Looking into the vents I can see green motherboard style interior so I didn't bother going any further. I gave the connections good blow (that sounds dodgy ) in the hope it would make a diff. Still no joy. Have you gone further and actually pulled the cluster apart?
I couldn't find the earth beneath the drivers seat with the fuse box. (As nick said earlier). I guess now I'll start trying to find loose earths elsewhere. Is there a list somewhere of earth locations for a 2012 ?
Cheers!
Tom
Post #533713 22nd May 2016 2:37pm
tomm
Ok. So I found the earth under the drivers wheel arch. One end looked as though it could tightened. As soon as I tightened it snapped clean off Evil or Very Mad so I'm wondering if it's OK to revonnect the earth to a neighbouring bolt?
As you can see in the picture there's the broken earth end on the left. And the bolt I'd like to connect it to the right.
It's not exactly part of the same chassis.
Also is the car undrivable without this earth correctly attached?
Post #533722 22nd May 2016 3:21pm
Yes, another bolt would be fine.
Just make sure it's pretty substantial and clean metal, probably best to spry a touch or rustproofing or grease or similar over it afterwards.
Post #533742 22nd May 2016 4:05pm
tomm
Thanks Steve. It's just been freshly waxoyl'd last week so not exactly clean bare metal. I can try and get as much of it off the bolt and I'll be using a fresh nut.
Post #533747 22nd May 2016 4:33pm
Telshe
England 2004 Defender 90 Td5 XS CSW Cairns Blue
The benifits of fitting a 1.222 gears to my TD5
Could somebody answer me some questions. I have been reading on Ashcroft Transmissions web site the benifits of fitting the 1.222 gearing to my transfer box. The sight states that it drops the revs down from 2919 at 70mph to 2530 revs about 15 percent.Does anyone know what 2530 revs relate to mph on my standard gearing l would like to hear and feel what it is like before committing my money to this project. I do a lot of motorway driving feel it would benifit me my passengers and my Landy. One last thing the tyres size are 235/85/16.
Many thanks for any comments
Telshe Very Happy
Post #533756 22nd May 2016 5:19pm
Snatch
United Kingdom 2000 Defender 90 Td5 PU Baltic Blue
I have not got a rev counter.. But it's the best mod you ever do to your land rover
Post #542164 21st Jun 2016 7:41pm
Cupboard
On the puma dashboard issue - I've had a similar problem where one of the relays under the dash by your knees had come loose. Shoved them all back in again and it started working fine again.
TD5 gearing (you'd have been better starting a new thread rather than tagging on to a completely different one btw): If 2919RPM is 70MPH on the old gears and that changes to 2530RPM on the new ones, a simple bit of maths using ratios give you the road speed for 2530RPM on the current gears. (70/2919)*2530=60.7MPH
However, bear in mind that's only the engine revs, wind noise (not that it's really noticeable in a TD5), transmission and tyre noise are not affected.
Post #542370 22nd Jun 2016 11:57am
tomm
Thanks Cupboard! I'll have another look under there.
Cheers,
Tom
Post #546536 6th Jul 2016 1:04pm
Alexke
Belgium
I had the same problem as described , I ended replacing my Cluster.
Mine came back to life when tapping the plexiglass or hitting it from the top.
I think mine had a loose connection somewhere. Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #546691 6th Jul 2016 9:13pm
tomm
They're not cheap are they? Did you buy a new one?
Post #547022 8th Jul 2016 6:57am
