Home > Technical > Defender 1997 3.5 V8 Power Increase |
Iggle piggle Member Since: 10 Sep 2014 Location: Wales Posts: 378 |
I think the inlet restriction plates were only fitted to stage ones & early drum braked 90/110 but could be wrong,
for the sake of removing a carb (easy job except for one bloody nut!) its worth checking I would also check the ignition timing or if you haven't got access to a strobe light try advancing it (turn the distributor clock wise) & take it on a short run, if it improves the performance either the base timing was wrong or the advance mechanisms aren't doing their job |
18th May 2016 10:37am |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 |
Your car should easily do 140-160km/h at around 18-22lt/100km average. My money is on a worn camshaft. m
25th May 2016 7:45am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Yes, i remember removing some restricter now you mention it, i think that might have been that plate...mine was B reg if i remember correctly Mike
25th May 2016 11:15pm |
I thought only the Stage 1 had restricters? m
26th May 2016 3:54am |
siwady Member Since: 28 May 2015 Location: Dubai Posts: 22 |
Sorry for not responding earlier as I was travelling ... but now I am back and ready to Rooollll!
Thanks a lot for the responses ... I will keep you updated with the progress or if I end up selling it again |
29th May 2016 5:29am |
