Home > Maintenance & Modifications > MT82 Output Mod - Help
Cetane
United Kingdom 2010 Defender 110 Puma 2.4 HT Galway Green
So I've replaced the clutch and have come to fit the MT82 output mod. My original was dry as a bone and had substantial wear.
So far I've followed the WSM to the letter and have got to the part where I fit the Ashcroft aluminium housing with its double O-rings at either end.
On the first attempt to fit it I tried with all the gubbins in place and with Loctite as I expected it to be a simple job and just whiz on. Only it didn't. After cleaning off the Locitite and trying to fit it a few times I figured out that If I removed the output shaft it span right on. As soon as I put the shaft in again, it feels like its cross threading.
I've attached a video to demonstrate the issue.
(Sorry don't know how to embed it)
http://vid12.photobucket.com/albums/a223/C...o4obz0.mp4
Note there are no O-rings used for this video. However, the ally housing will screw on to the output "cup" with the 2 large O-rings in place. It just makes things stiff, so they are not to blame which was an early thought of mine.
Another thing to note was that upon disassembly of the first attempt there was a thin sliver of ally where the 2 large grooves are either side of the cup. I decided to take a needle file to the leading edges to give them a chamfer, as my initial assessment was that the thread on the "cup" was acting like a tap.
I'm now at a loss!?!
Any help gratefully received.
Post #532411 17th May 2016 4:35pm
Happyoldgit
Interesting, as the housing spins on freely on its own but not with the shaft in place, and as it is such a snug on the shaft, fit do you think it points to a misalignment in the splines & shaft as that is what it strikes me as. Steve.
http://forums.lr4x4.com
Post #532421 17th May 2016 5:09pm
Cetane
Happyoldgit I had considered the same. But the misalignment would probably have to be obvious for the issue to manifest...
Anyroad I think I have it sussed. I took some measurements using the blue line that I marked to show me when the ally housing was home as a datum. It looks like the output shaft hasn't been ground down close enough to the gearbox end. It just happens to bottom out when one thread has engaged on the housing. I tested the hypothesis by whacking the shaft in further beyond its spring clip detent and was able to get a few more turns onto the housing.
Will give Ashcrofts a ring tomorrow to see if they agree.
Photos attached for anyone interested.
Measurements displayed are for reference and not 100%.
Post #532437 17th May 2016 6:11pm
R1200GS
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Keswick Green
How did you get on?
Thanks for the video too
Post #533354 21st May 2016 8:19am
Cetane
All sorted now.
See here....
http://www.defender2.net/forum/topic2032-13650.html
Post #533415 21st May 2016 1:56pm
R1200GS
Thanks for that Very Happy
Did you fit the IRB paddle clutch as well? How are you finding the two mods combined?
Very interested in your thoughts as planning on doing this myself.
Dave
Post #533428 21st May 2016 3:22pm
Cetane
I have done both but the 110 wont be on the road for a while. Got a lot of big jobs to do.
Will defo report back when done.
Post #533433 21st May 2016 3:54pm
What actually was the problem?
Post #533448 21st May 2016 4:36pm
Cetane
The ally housing bottomed out before tightening up on the threads. Ashcrofts sent out a new ally housing and output shaft and it went together perfectly. Hopefully it will do the trick!
Post #533456 21st May 2016 5:22pm
LR90XS2011
hi Cetane how has the clutch and shaft worked out? DEFENDER 90 TDCI XS,
Post #556537 16th Aug 2016 8:19pm
Cetane
Sorry for the delay in reply.
Not been on the forum in a while.
Have been busy with other things, and only really got the 110 back on the road a couple of weeks ago.
The ceramic clutch was poo. Rattled like mad due to poor build. Swapped it out for an organic jobby which seems to be ok.
Not done enough miles yet to comment on the output mod. No leaks as yet though.
Post #582189 2nd Dec 2016 3:11pm
Jano300783
Spain
Well this week I downloaded the transfer to repair it and when you remove it you see the output shaft that comes from the gearbox. The case is that the striation is quite worn and wanted to change it, but there is no way to loosen the screw. So I am giving Sticks of blind since I do not know if it looses right or left.
Has anyone ever taken it apart?
Post #643607 13th Aug 2017 11:48am
Jano300783
Spain
Post #643608 13th Aug 2017 11:49am
