Home > Puma (Tdci) > Lumpy steering?
N16kct
United Kingdom 2010 Defender 110 Puma 2.4 USW Corris Grey
Lumpy steering?
I noticed the last time I drove my 110 the steering felt a bit... notchy/lumpy when turning right at low speed. I'm not getting feedback with the wheels rotating, its just when turning the steering wheel.
Something isn't right Neutral
Post #531998 16th May 2016 1:47pm
Happyoldgit
Check the steering column. Steve.
http://forums.lr4x4.com
Post #532051 16th May 2016 4:13pm
williamthedog
Might be worth putting some oil on the steering ujs.
Happened to mine before ,I just oil them once in a while Thumbs Up
Post #532080 16th May 2016 4:58pm
N16kct
Thanks chaps, I'll have a look at this today Thumbs Up
Post #532240 17th May 2016 7:35am
Cetane
United Kingdom 2010 Defender 110 Puma 2.4 HT Galway Green
Checked PAS fluid level?
Post #532254 17th May 2016 8:57am
With the engine running it might be worth getting someone to wiggle the steering wheel,and check the steering box for excessive play.
Hopefully not that though.
Post #532255 17th May 2016 8:59am
nickhodgson
Oil the steering UJs? You mean the two between the steering column and steering box? How does the oil get into the joint?
I agree that you should vigorously shake the steering and look for play. Otherwise look for any bent steering rods that are touching something else. You can pop off the tie rod ends and check them and the swivel bearings as well. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #532264 17th May 2016 9:20am
williamthedog
Yes the joints on the steering column.
Mine felt notchy so I just oil them occasionally.
It might be the turbo drying out the top uj.
Post #532344 17th May 2016 12:58pm
Happyoldgit
Classic symptoms of steering column joint/s issues. Steve.
Post #532424 17th May 2016 5:11pm
