Home > Puma (Tdci) > Lumpy steering? |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Check the steering column. Steve.
16th May 2016 4:13pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Might be worth putting some oil on the steering ujs.
Happened to mine before ,I just oil them once in a while |
16th May 2016 4:58pm |
N16kct Member Since: 24 Aug 2015 Location: Oxfordshire Posts: 151 |
Thanks chaps, I'll have a look at this today
17th May 2016 7:35am |
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 |
Checked PAS fluid level?
17th May 2016 8:57am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20468 |
With the engine running it might be worth getting someone to wiggle the steering wheel,and check the steering box for excessive play.
Hopefully not that though. |
17th May 2016 8:59am |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 |
Oil the steering UJs? You mean the two between the steering column and steering box? How does the oil get into the joint? I agree that you should vigorously shake the steering and look for play. Otherwise look for any bent steering rods that are touching something else. You can pop off the tie rod ends and check them and the swivel bearings as well. 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
17th May 2016 9:20am |
Yes the joints on the steering column.
Mine felt notchy so I just oil them occasionally. It might be the turbo drying out the top uj. |
17th May 2016 12:58pm |
Classic symptoms of steering column joint/s issues. Steve.
17th May 2016 5:11pm |
