Home > Td5 > Noisy when hit bumpy road?
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
2003 TD5, I found its very noisy when the car over bumpy road, sounds like the car is falling apart!
any idea what should look at? suspension? bushs?
Please help Bow down
Post #531896 16th May 2016 7:04am
rallysteve
Rear shock bushes,
A frame ball joint
Spring pans
For a start 02' 110 TD5 Double Cab Rebuild Thread
Post #531899 16th May 2016 7:13am
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
The lower rear shock bushes wear out pretty quickly and give a terrible noisy ride when they have. Extremely cheap and quick to change.
Look at the bottom of the rear shocks when bouncing the rear end up and down by hand. If there is any loss of contact between the bush and the shock/retaining cups they need replacing.
Post #532090 16th May 2016 6:18pm
geobloke
Bushes in general I would say, especially the shock bushes and anti roll bar bushes.
What pressure are you running your tyres at?
What springs have you got on? HD springs will jar the truck around instead of conforming to the road.
Post #532099 16th May 2016 6:40pm
Screbble
Re: Noisy when hit bumpy road?
Sounds about right to me Confused
My wife frequently tells me that she thinks the Landy is falling apart - rather like its owner Shocked
As others have said, plenty of suspension bushes to keep you occupied and many are cheap and easy to fix Thumbs Up
Post #532124 16th May 2016 7:37pm
lightning
On my 2005 TD5 it was the rear shock lower bushes. I replaced them but they didn't last more than a few months.
So l fitted poly ones (but not the hard compound type) and all has been fine since then.
Post #532137 16th May 2016 8:08pm
RF3777
Why would the rear bushes wear out quicker then the front? the front is heavier, right?
BTW, Thank you all giving the input!
Can the panhard rod do the noise??? Question
Post #533603 22nd May 2016 6:05am
RF3777
All original setting, front/rear tyre pressure is 36/48 Psi.
Post #533604 22nd May 2016 6:12am
RF3777
Like to update on this issue, end up is the front shocks dead, and all bushes are gone!
now with new shocks and all new bushes replace, it roll fine again!
I can not remove the turret from top hole of inner fender, because the metal inner fender has block about 3mm of the bottom of the turret...
i need to use a long metal stick to make the fender more room for the turret, also there is a plactic inner fender blocking the turret, but I was able to remove the turret with shocks from under the wheel arch!
Post #539979 14th Jun 2016 6:44am
