![]() | Home > Puma (Tdci) > Annoying little resonance |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I also have this in mine, quite a big resonance in mine though as i feel i have to ease off the throttle until on flat ground again ha
I've not sourced the problem yet due to not being at home with the truck for a couple months but I believe it will be a union joint on the prop-shaft or an output shaft bearing from transfer box or diffs... Just my 2p worth anyways, ill stay tuned and maybe you'll find a solution before I do ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Possibly prop balancing or possible UJ's, but those are just a guesstimate.
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
Had the same issue for a while. End up with front bearing of the transfer box. Until I have replaced it I have tried balancing props and other potential sources. Is your car lifted? I link this and some other issues to 2 in lift.
Cheers! Janusz www.yahodeville.com |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
Not lifted and ujs are fine.
How can I check if it is the transfer box bearing? |
isy02 Member Since: 20 Apr 2015 Location: inverclyde Posts: 10 ![]() ![]() ![]() |
Hi zone30
Just in case have a look at the turbo heat shield if you have a Traci,a small crack in the shield can also produce similar symptoms. Cheers |
Sorry should read Tdci,should have put the reading glasses on.
Will do, thx!
Fixed the heatshield. I did a testdrive and most of it seems to be gone. Will know for shure in a week of so when I've driven some more.
Thx for the tip! |
Great that it looks to have sorted your problem,took me ages to figure mine out
All the best. |
Much better but not completely gone...
Needs a second look. |
