Home > Puma (Tdci) > What are these things? |
First picture, what is the thing on the left that looks like a bit of scrunched up tin foil, and what's the hat that it goes under? Should the hat be attached on properly rather than just flapping around?
Click image to enlarge Second, has anyone ever seen a dent in this pulley before, any ideas what has caused it and do I need to be careful when ordering a new one? Click image to enlarge Thank you [/img] |
15th May 2016 7:50pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
First one is a heat shield that sits over the twin wire electrical plug on top of the bell housing, flywheel sensor.
Common to see them come adrift, or missing. The alloy pop rivet rubs due to vibration then becomes loose. Also a cause of an annoying rattle! Can't say what caused the dent in the tensioner pulley? Maybe someone had a lever or bar against it at some point?? Or a long shot would be something got trapped between belt and pully while running? I would go for it being used as a lever point for something.... 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
15th May 2016 8:01pm |
Beat me to it Mick! 80" 80" 86" 88" 90"
15th May 2016 8:02pm |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 |
First time in a long time I have beat anyone to anything!
;-( 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
15th May 2016 8:07pm |
80" 80" 86" 88" 90"
15th May 2016 8:13pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20356 |
I'd say the same for the pulley, it's right next to the pretensioner so you need to use a lever to remove the belt.
However, looks like it wasn't done carefully and who ever it was was forceful and crack handed. I used a crowbar on mine to remove the drive belt myself and never caused anything similar. I wouldn't worry about it at all though if it's just the edge of where the belt is, looks just like the very outer edge. LR would probably want £100 for a new one. |
15th May 2016 8:28pm |
It's running on the back of the belt and doesn't seem to be causing any issues. I'm just not particularly happy with knowing there's something not right! Engine has never been out that I'm aware of.
So are you saying the heat shield isn't needed? It seems to be trying to make a bid for freedom And what about the bit of scrunched up foil that goes under it? |
15th May 2016 9:39pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17374 |
My Puma has been miising the crankshaft position sensor heatshield for at least the last 150,000 miles, so I don't think you need worry too much.
15th May 2016 9:52pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
Looks like the sort of dent I'd inflict when going for something with the size 1 adjuster and missing to be honest. I wouldn't be worrying.
15th May 2016 10:19pm |
