Home > Maintenance & Modifications > Rear Camera Install |
Good job and nice write up! Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
13th May 2016 7:57pm |
mcl001 Member Since: 14 Sep 2015 Location: Pembrokeshire Posts: 31 |
Is it me or is the image flipped from right to left?
13th May 2016 8:34pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3772 |
^ Hello
Not sure what you mean, I have moved the camera angle in a couple of the pictures above so it may look wrong? The camera is off set as set under the number plate. Click image to enlarge This is the view when I moved the camera angle down to show the step, is seems to show the correct side with the number plate on show? I will have a proper look over the weekend if I get chance always busy doing stuff Click image to enlarge |
13th May 2016 8:49pm |
When you look from behind the camera in the line of sight, the spare wheel is on the left. On the screen it is on the right, so yes I guess it is flipped from left to right. Most screens have a function to flip the image so you can correct for this, dependent wether you use the camera as a front or rear camera. Cheers, Vincent
13th May 2016 9:41pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1836 |
Nice write up.
How much adjustment is there in the lense angle? 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
13th May 2016 10:03pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20483 |
If anyone has a 2DIN HU or 1 DIN with monitor you could hook a cam straight up to that too.
I've never fitted one due to considering a Blackvue, but that's been on a back burner for a while due to cost. Pretty much anything with the yellow pre out video source can be interchanged. What ever you fit the spare wheel often gets in the way of view. The good thing with this little cam is the fact you can mount it into the plate light mount, of which is completely reversable I.e, body drilling isn't required and the plinth is cheap to replace. |
13th May 2016 10:45pm |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 597 |
Also got mine in yesterday, this thread really prompted me to get on with it.
Just need to find the connection for the reverse switching on the head unit so that it comes on automatically when reverse engaged. Click image to enlarge I was initially worried about the angle from mounting it on the number plate light but find it gives great perspective as you approach a vehicle, I watch the bracket for the bike rack and comfortably get to about 2cm away when it looks like we are about to touch. Will be careful with approaches at an angle until fully tested. |
14th May 2016 12:49am |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 |
Great write up. I really need to get myself sorted with one. Trying to reverse up to anything another than a wall in my 130 is a nightmare. With no rear window and the tub wider than the body you loose sight of any car behind.
14th May 2016 4:20pm |
Hello
The camera lens can move 100 degrees, so I need to mess about with the view. There is no option on the screen to change the 'flipped view' any idea how I can do this? I've only used it a little over the weekend but already its useful, The camera lens is on the left (near numberplate) athough as stated the view on the screen looks to show Click image to enlarge |
15th May 2016 7:25pm |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 |
Oooooh, something else for the list of wants now. Once I have the single din stereo, the will be next.
Out of interest, is it solely visual? Or is there a reverse-sensor type beep too? |
16th May 2016 11:48am |
Hello
Just visual, My wife cars beeps and the beep gets louder as you get near, I find that a bit annoying. Even more so if your towing and reverse without and over ride switch Some cameras have a sensor that beeps also as part of kit so depends what you want I guess. Used it today in a parallel park bay and it worked very well. Wall along side me and car behind. |
16th May 2016 11:52am |
Update just to show how it works, today parallel park against a wall with car behind.
So picture of car showing one behind. Click image to enlarge Then view from inside the car looking back in a Defender its pretty hard to see any normal sized car once its right behind you and close. Click image to enlarge Then view from camera screen, I could back my truck up right up to this with far more confidence than just using the towbar as a sensor Click image to enlarge I May move the camera angle slightly to see what views I can get but happy with it |
16th May 2016 2:21pm |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
Looks good
On my list of upgrades when I get my 110 2020 P300 HSE |
16th May 2016 2:44pm |
I just ordered a camera
I have some aftermarket audible sensors in the shed, toying with adding them too. But like you say, the beeping can get annoying |
16th May 2016 2:47pm |
