![]() | Home > Maintenance & Modifications > Rear Camera Install |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
very tidy install, I think I will do the same when I fit a double din, looks to be useful for trailer hitching too! Thanks for the info! My 90 Project : http://www.defender2.net/forum/topic52774.html
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 ![]() ![]() |
Have you figured out how to flip the image yet? Would this camera work equally well if set higher up on the vehicles rear? Thanks
Hi, your link seems to link to a numberplate kit and not the little camera you show in the pictures. Have they changed their link. Thanks Mark |
I found the same, the link is not the same camera any more
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3818 ![]() ![]() |
Hello
I've changed the screen as the flip up unit didn't seem to like being flipped so often.... Still not managed to flip the screen but I still find the view very good, getting you much closer than I could looking in the mirror / behind. ![]() Click image to enlarge |
This looks like the same camera
https://www.ebay.co.uk/itm/132045201839 My 90 Project : http://www.defender2.net/forum/topic52774.html |
^ Thats the same one
![]() ![]() Click image to enlarge |
Thanks Stacey! Now delivered and fitted as per your instructions
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
Thread revival
I only got around to fitting mine last week. I was re-covering my headlining so thought it a good time to start/finish the reverse camera. I don't like the idea of a dash mounted screen and my radio is only single din with no screen. So as my visors are already off for relining in black to match the front and back, I decided to fit in in there ![]() As you can see by the pic, still needs some tidying and finally the material covering but works great in practice. Both screen and camera power wired into the reverse light. Takes half a second if that to display. Picture attached was with camera not in final position. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge TD5 Defender 90 Discovery 3 HSE |
![]() Great stuff is your image the correct way, still think its a great mod. |
Ha, nope. But I seem to remember there being two little wires at the camera end. Really really small ones, one black and one white from memory. I think cutting one of those flips it but I want to make sure before I do it
![]() Discovery 3 HSE |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 ![]() ![]() |
Most screens have buttons to flip the image horizontally and vertically by software, I would look for that first.
![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Mine doesn't. Boooo
Mine does not either and I've had two different screens now...
Still works very well and very handy for getting mighty close.. |
