Home > Technical > early defender doors
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Hi Guy's
Just wondering could you fit electric windows to the early defender doors, the wind up window/lift up handle. I know it probably defeating the whole period look, but I'm lazy lol
Shane
Post #530938 12th May 2016 9:56am
spudfan
Ireland
I have a Puma with electric windows and a tdi without. The door trim on the Puma is wider than the trim on the tdi so I presume this is to accommodate the motor and electronics for the electric windows. Should be possible to fit but you might need to change the door card aswell. Some counter sunk self tapping screws will hold the new trim on and you can cover the holes for the screws with some trim button tops glued over the holes. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #531160 12th May 2016 10:41pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Re: early defender doors
shanecl wrote:
Hi Guy's
Shane
I don't know for certain but I can't think why not. I've done the conversion on the later doors with the push button handles. The electric window mechanism sits in the same place as the manual winder system and I found the easiest way to convert them was to buy the inner door panel that the electric version mounts on.
The actual winder mechanism mount on the window was different so I ended up using a part of the original winder mechanism and part of the electric one.
I'm not sure if the door cards are any deeper on the electric ones, I don't think they are because I'm pretty sure I used the original door cards while waiting for the right ones to pop up on eBay. http://www.yorkshireoffroadclub.net/
Post #531162 12th May 2016 11:19pm
shanecl
Thanks Guys,
When I find a pair I might just buy the one elec mechanism, and see how I go
Shane
Post #531255 13th May 2016 11:54am
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Ooooh, interesting.
**goes off to eBay in search of the kit**
Post #531260 13th May 2016 12:31pm
waxrover
Australia
bringing up an old thread here.
has anyone done it?
did you cut into the inner door panel or throw in a puma one? will it all fit in an 85 with lift up handles?
thanks! IG: @classiconeten
Post #896435 7th Apr 2021 10:38am
V8Simon
United Kingdom 1985 Defender 90 V8 Petrol SW Auto Arles Blue
I've 1985 lift up handle doors and want to fit electric windows when I redo my doors as getting fed up of sweeping rust out when I get in. Rolling Eyes
I'm sure I've seen posts in the past about doing it so taking it as possible and just need to decide to go down the generic kit route or as per one of the prev posts, and use a new LR inner panel to mount the motor and assorted fixings to. Also conscious a lot of the parts for the early doors were superseded and no longer available. 1984 90 V8 puma want to be.
Post #897993 13th Apr 2021 2:25pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Are Puma and earlier inner door panels the same size? chatting to a guy a while ago he mentioned he'd bought brackets to add Puma electric windows to his 300 tdi. Something like this I believe
Post #898012 13th Apr 2021 3:39pm
V8Simon
Short answer is I don't know, I've been led to believe they are but not sure why I think that. I know Lucari do a window kit for later models https://www.lucari-solutions.co.uk/catalog...tegory/67/ so in my head they must be otherwise this would work for mine???
I might take my door card off at the weekend and take a photo to look. Slightly worried at doing it in case I find its all dust..... 1984 90 V8 puma want to be.
Post #898014 13th Apr 2021 3:45pm
Slideywindows
I've been working on an '84 Ninety (lift-up handle) door and more recently a very early (1990) Defender door.
I cannot answer your question, except to warn that the earlier door is much thinner in profile than the later door, so you may need to be sure any new mechanism will fit between the card and the door-skin on the thinner door - unless you want even less elbow and knee room.
Post #898024 13th Apr 2021 4:11pm
Horneteer
United Kingdom 1986 Defender 90 200 Tdi SW Firenze Red
Its not the gap between the skin and the card you need to worry about. It's less than that as you've only got the gap between the glass and the card to play with. On a slightly different track, I fitted central locking to my lift up handle doors and it was tight with the locking solenoid, they are against the card and the window mech just misses as the window drops.
Post #898074 13th Apr 2021 8:14pm
V8Simon
Thanks Horneteer, so I guess the challenge is now to find someone who has done it and posted about it from sometime in the last 30+ years Shocked
Challenge accepted..... Rolling Eyes 1984 90 V8 puma want to be.
Post #898141 14th Apr 2021 9:09am
V8Simon
Humm not as much info as I'd hoped. This is all I've found so far however a couple of posters to say they'd done it and what they used. Seems its possible, or was in 2013.
https://forums.lr4x4.com/topic/84520-fitti...truck-cab/ 1984 90 V8 puma want to be.
Post #898148 14th Apr 2021 9:34am
roel
It might not be as straightforward as you think. I found that the manual lifting systems from a 1984 door and a 2003 td5 door are so much different that I used the 2003 window as well.
The metal inner door plates are different too. I am believe I had to drill some new holes to fit the 2003 manual mechanisme. Roel
2003 90 Td5 (2009-now)
Post #898176 14th Apr 2021 12:26pm
