Home > Puma (Tdci) > ABS/ Traction Control - was it standard on the Puma 2.4? |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
Not all of them had ABS.
A mate has a MY11 without but it is unusual in our market not to have it. To confirm if it's fitted look for the pump under the bonnet. Something like this... https://encrypted-tbn2.gstatic.com/images?...lhCiOch85f Cheers, Kyle. |
12th May 2016 4:13am |
Mine is ex UK.
Thanks for the picture (and the hand for scale!). doesn't look familiar, but there is a lot of stuff jammed in there. Will be interesting to see later tonight, is it located near the brake servo? (driver side, i.e. on the upper left when looking back for us). Solved the bowel problem, working on the consonants... |
12th May 2016 4:17am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3639 |
in the UK it was standard on XS models and an option on others upto 2011 DEFENDER 90 TDCI XS,
12th May 2016 5:06am |
Assuming I don't have it ( ), and that I know what it does, the benefits etc. - how much of a game changer really is it:
- Driving around a muddy farm. - Off-roading. - Sealed roads in the rain. Looking for real world experience here Solved the bowel problem, working on the consonants... |
12th May 2016 5:10am |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Mine hasn't got it, i haven't had any problems without it off road.
Its just more to go wrong in my opinion. |
12th May 2016 5:14am |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
I read somewhere that ABS works for 0.00000256% of a vehicles lifetime but that 5 seconds will probably save your life. TC now that's a game changer. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
12th May 2016 5:23am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
I ordered a 2011 "County" spec...because I DIDN'T want TC & ABS
Not missed it yet. My plan is for an Ashcroft ATB instead (when I get around to it) of TC.... http://www.ashcroft-transmissions.co.uk/di...-diff.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
12th May 2016 5:27am |
I've rarely seen my traction control do anything except when on an axle twister and then some revs resulted in it transferring power to the wheels on the ground and got me moving.
There are lots of threads on here about it and the benefits and dis benefits. Locking axles are probably more useful off road, however ABS could prove immensely valuable if someone pulls out in front of you on a wet road DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
12th May 2016 5:29am |
Hell yeah, we 4X4 guys are tuff, we have roof racks with nuclear LED's and spacehopper tyres on our Tonka trucks but who needs ABS? The kid running out in front of you on a moist road, that's who! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
12th May 2016 5:51am |
Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170 |
Hello guys, Mine's a 2.2 and neither ABS nor TC
I prefer the direct feeling when riding my Defender. - J |
12th May 2016 6:51am |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
I don't think anyone would disagree that ABS is useful in that circumstance, but just because you choose not to have ABS, it doesn't mean you're a reckless idiot. Personally I chose to forgo ABS/TC deliberately due to the added complexity - same for heated screen and seats. For me I prefer to accept that I need to drive carefully and in accordance with the conditions in all circumstances as I do not have the back up of an electronic aid. I also run XZLs on my 110, which aren't ideal wet road tyres so I drive accordingly. You'll find the largest fleet of 90s and 110s in the country do not have ABS/TC and run XZL or G90s ... |
12th May 2016 8:42am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
This is a Wabco ABS pump Click image to enlarge Think Landrover fitted Bosch pumps eventually...Not that they're any better,lol. Click image to enlarge Both look similar,you'll find them in the top O/S position under the bonnet (assume the opposite for left hookers). Also the brake master cylinder on an ABS only has two brake pipes (1 front 1 rear,non-ABS has 3.....2 front 1 rear). Pov.spec,ftw. 2006, 110,TD5. |
12th May 2016 9:37am |
With the Defender you can't have T/C without ABS. Pov.spec,ftw. 2006, 110,TD5. |
12th May 2016 9:40am |
As said,axle lockers are better than T/C.If you wished you had ABS fairly often maybe you could slow down a bit !! Pov.spec,ftw. 2006, 110,TD5.
12th May 2016 9:41am |
