Home > Puma (Tdci) > Gear change, First to Second 'nick' |
ter11 Member Since: 28 Oct 2015 Location: Zurich Posts: 26 |
Bad news, but much appreciated!
Ter |
11th May 2016 8:40am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
I do think mine is improving with age.
Just started driving her again ... been garaged since October!!! (other projects/pressures, then a cycling accident put me out from driving for 2 months). At 30,000 miles, with the LTB00585 mod done, and now 2 changes of gearbox oil, she seems a bit better. Still needs to change 1-2 slowly and deliberately... but getting better Only time she's bad is when cold, on a hill start, when you need to be quick 1-2 to keep momentum... Bizarre, but 1st time I changed the oil, I used "upgrade" Castrol synthetic oil,... but most recent oil was "carplan" cheap stuff (still with correct properties) from Halfrauds... I think the cheap stuff may help!!! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
11th May 2016 8:48am |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
Ditto what AgentMulder said.. I changed the clutch plate and cover, bearings, fluids, gearbox output shaft.. Still the same cr4ppy MT-82 we've all come to loathe and hate! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
11th May 2016 6:21pm |
Erik256 Member Since: 05 Mar 2013 Location: Tallinn Posts: 23 |
Same here. Changed the clutch and main bearing, installed the shims, tried different oils (Motul 3000) and additives (Ceramic Power Liquid), adjusted clutch travel and tried driving with or without rubber mats. No real difference.
I Read from here (http://www.defender2.net/forum/post87098.html) that Ford recommends a special friction modifier for Mustang gearboxes (they also use a version of MT82 and have reputation for poor shifting). Haven’t yet tried this, so maybe worth a try. Tough I haven’t seen the additive for sale on this side of the pond. |
12th May 2016 11:46am |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3785 |
Like I said,..basically, "It is what it is",,, Pickles. |
12th May 2016 10:29pm |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1645 |
Yup!
But they don't all do it! YOLO... You Only Live Once... |
12th May 2016 10:43pm |
Ok, sooooo, check it out if you haven't already:
http://www.defender2.net/forum/post537600.html#537600 edit> just realised that thread is a sticky, very likely you've all read it... Anyway, FWIW in my case it's been helpful - and I mean that, it's not just me justifying a morning's work Solved the bowel problem, working on the consonants... |
5th Jun 2016 3:57am |
OK, spent a tank of diesel so far with the insert mod.
Seriously better. Took a while to get used to it actually, just to plonk it into second directly. But of the I dunno, hundreds of changes (?), I recall one hands worth with any hint of a 'croik' noise, and even then it was minimized. For me and my vehicle, I'd consider this case closed (YMMV). Solved the bowel problem, working on the consonants... |
6th Jun 2016 7:30pm |
