![]() | Home > Puma (Tdci) > 2015 110 Damp Footwell - rapair update |
Quite a common fault, my mrs's double cab had the same leak fixed under warranty. I've read the rust comes from and uncoated/unpainted piece of metal or bracing behind the dash. Lr should pay for the full fix. Ray
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3790 ![]() ![]() ![]() |
When you say "Windscreen to Bulkhead", do you mean the foam seal area?...or where the w'screen rubber seal seals against the bodywork,.....a pic maybe?
Pickles. |
Moles Member Since: 17 Mar 2016 Location: Wiltshire Posts: 40 ![]() ![]() |
Sorry, I'm just quoting what the dealer found, not seen it myself, but I'll try to get a more detailed explanation when I go see them.
Moles. |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
Yep the foam seal is a very common failure. Dealer did mine........ Not that, reckons it was missing bolts in the footwell and.....................
This happened last week ![]() ![]() Click image to enlarge so its not that either ![]() ![]() |
This is nothing new and the screen to bulkhead seal has been a potential problem area since the introduction of the 90 & 110 back in the '80's. Steve.
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
And there have been lots of different part numbers for that seal....... 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
...and the quick cure is to pull the door seals out and run a bead of sealant along the entire join including around the ends / corners where the door seals fit. Steve.
