Home > Puma (Tdci) > 2015 110 Damp Footwell - rapair update |
Quite a common fault, my mrs's double cab had the same leak fixed under warranty. I've read the rust comes from and uncoated/unpainted piece of metal or bracing behind the dash. Lr should pay for the full fix. Ray
7th May 2016 10:10pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3781 |
When you say "Windscreen to Bulkhead", do you mean the foam seal area?...or where the w'screen rubber seal seals against the bodywork,.....a pic maybe?
Pickles. |
8th May 2016 1:24am |
Moles Member Since: 17 Mar 2016 Location: Wiltshire Posts: 40 |
Sorry, I'm just quoting what the dealer found, not seen it myself, but I'll try to get a more detailed explanation when I go see them.
Moles. |
8th May 2016 8:46am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1419 |
Yep the foam seal is a very common failure. Dealer did mine........ Not that, reckons it was missing bolts in the footwell and.....................
This happened last week Click image to enlarge so its not that either They've only had it for 16 days. looks like they'll have it some more |
8th May 2016 12:21pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
This is nothing new and the screen to bulkhead seal has been a potential problem area since the introduction of the 90 & 110 back in the '80's. Steve.
8th May 2016 5:22pm |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 |
And there have been lots of different part numbers for that seal....... 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
9th May 2016 1:05pm |
...and the quick cure is to pull the door seals out and run a bead of sealant along the entire join including around the ends / corners where the door seals fit. Steve.
9th May 2016 2:53pm |
