Home > Puma (Tdci) > Creaking/Clicking/Ticking Noise - Rear door related? |
Yip, but mine was related to the interior plastic trim edges creaking against each other... Solved the bowel problem, working on the consonants...
5th May 2016 8:06am |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
Mines only started creaking after I gave the hinges a skoosh of WD40. It now creaks ( suspect the hinges themselves ) when I hit bumps on the road or even slow speed when there may be a bit of body twisting going on. I've not investigated yet, but it's very annoying.
5th May 2016 8:18am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Have you taken the rear door card off to have a look inside?
Mine made all sorts of creaks, knocks etc. The inside door frame had split from side to side! It was a right mess! 18" alloy with BF Goodrich hanging off the back was just too much for it! Now fitted wheel carrier, and standard rims. No more noise😄 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
5th May 2016 8:44am |
My spare was removed (i.e. door card taken off to remove bracket also), creak continues ...
Sat in the back with another driver going round a block with speed bumps, found the location, took a while to find the actual cause though, solving it is far down the list of priorities. (wax?) Solved the bowel problem, working on the consonants... |
5th May 2016 8:49am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
You probably washed the grease out of the hinges using WD40. Try a light oil,3in1 is good,but be aware you need to apply fairly regularly(also wipe away the excess for the next few days).And try to squeeze some very light grease in there. WD40 is usually a very temporary solution. Pov.spec,ftw. 2006, 110,TD5. |
5th May 2016 10:26am |
Jimbob7 - good call. I've given the hinges a wee drink of 3in1, will see how it goes. I have spray grease which I could try - very delicately though.
5th May 2016 3:11pm |
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 |
WD40 is a temporary solution... so much so that everytime I visit my parents, my Father douses the puma in it... its made no difference at all except oily stains both inside and out... No creaks yet though...just rusty nuts |
5th May 2016 4:23pm |
jimbob7,
You have saved my sanity - after dousing with 3in1 my hinges are nice and quiet again. |
7th May 2016 11:29am |
