Home > Td5 > 110 CSW rear window trim panels |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
Mine were flat side towards the panel Ray
6th May 2016 7:15pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5873 |
Thanks - that's tomorrows job after fitting more foam on the metal work around the windows 1999 Defender TD5 110
6th May 2016 7:37pm |
Sussed - Wrong hole!
The correct hole is the one to the left of the bolt head in the picture. Trim panels back on with some foam behind to try and reduce noise and stop rattles. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
7th May 2016 11:00am |
Sorry, should have said. The hole its in in the picture is used to position the plate. Ray
7th May 2016 6:50pm |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 |
beat me to it. I just removed mine today. Horizontal straight thru with flat surface to the panel and use the other whole to locate screw.
18th May 2016 9:08pm |
