Home > Td5 > 110 CSW rear window trim panels
excossack
Do the captive nut plates used to hold the trim in place around the rear sliding windows on a 110 CSW have the captive nut facing towards the panel or flat side towards the panel.?
This is the lower section of the trim that has three screws going through. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #529574 6th May 2016 4:22pm
mk1collector
Mine were flat side towards the panel Ray
My build thread
Post #529596 6th May 2016 7:15pm
excossack
Thanks - that's tomorrows job after fitting more foam on the metal work around the windows 1999 Defender TD5 110
Regards
John M0VAZ
Post #529601 6th May 2016 7:37pm
excossack
Sussed - Wrong hole!
The correct hole is the one to the left of the bolt head in the picture. Trim panels back on with some foam behind to try and reduce noise and stop rattles. 1999 Defender TD5 110
Regards
John M0VAZ
Post #529710 7th May 2016 11:00am
mk1collector
Sorry, should have said. The hole its in in the picture is used to position the plate. Ray
My build thread
Post #529794 7th May 2016 6:50pm
Lancerdoc999
beat me to it. I just removed mine today. Horizontal straight thru with flat surface to the panel and use the other whole to locate screw.
Post #532799 18th May 2016 9:08pm
