Home > Puma (Tdci) > Puma 2.4L fuel filter priming via syringe?
agentmulder
Kuwait
Been reading all the Puma 2.4L fuel filter threads...
So I'm wondering if a syringe like this would do the job:
I've already got one, so I figure I can:
- suck through diesel into syringe at engine end
- put this filtered diesel in new filter along with a wee bit of oil on the rubber seal (this step replies on syringe being clean and clear itself)
- remove old filter
- replace with new filter
then either
- turn on ignition and let it run with a few revs for a few mins, job done (?)
or:
- suck diesel at engine end until any air has been pulled through (i.e. a 'bleed')
Sound reasonable?
Post #527964 30th Apr 2016 5:54am
williamthedog
All I do is fill up filter with clean diesel,take off old filter quickly.
Fit new filter start up and just keep the revs up for 2-3 minutes.
I haven't had any problems. Thumbs Up
Post #527965 30th Apr 2016 6:04am
agentmulder
Kuwait
That seems to be the standard way to go about it and I'd do it, but I just got thinking about the 'problem' of unfiltered diesel particles in the injectors (that doesn't appear to have happened to anyone) and the occasional story of hiccups because of air in the line.
My suggestion was prompted by the thread with the inline pumps:
http://www.defender2.net/forum/topic516.ht...p;start=30
But I thought I'd rather use what i have on hand Smile
Post #527967 30th Apr 2016 6:08am
williamthedog
No harm in using a syringe if you got one Thumbs Up
Post #527970 30th Apr 2016 6:14am
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
I would be a little cautious using one of those metal syringes, I have two and both were full of metal swarf when new.
If any of this goes into the injection system hello big bills...
Post #528876 3rd May 2016 9:17pm
agentmulder
Kuwait
Thinking I'll just use it to do the suction part and not to source the filtered fuel for the filter. Should be OK as the fuel will end up in a bucket and not the injector Thumbs Up Solved the bowel problem, working on the consonants...
Post #528907 3rd May 2016 9:58pm
