Home > Puma (Tdci) > Puma 2.4L fuel filter priming via syringe? |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
All I do is fill up filter with clean diesel,take off old filter quickly.
Fit new filter start up and just keep the revs up for 2-3 minutes. I haven't had any problems. |
30th Apr 2016 5:04am |
That seems to be the standard way to go about it and I'd do it, but I just got thinking about the 'problem' of unfiltered diesel particles in the injectors (that doesn't appear to have happened to anyone) and the occasional story of hiccups because of air in the line.
My suggestion was prompted by the thread with the inline pumps: http://www.defender2.net/forum/topic516.ht...p;start=30 But I thought I'd rather use what i have on hand |
30th Apr 2016 5:08am |
No harm in using a syringe if you got one
30th Apr 2016 5:14am |
Jonno Member Since: 06 Mar 2012 Location: Yorkshire Posts: 234 |
I would be a little cautious using one of those metal syringes, I have two and both were full of metal swarf when new.
If any of this goes into the injection system hello big bills... |
3rd May 2016 8:17pm |
Thinking I'll just use it to do the suction part and not to source the filtered fuel for the filter. Should be OK as the fuel will end up in a bucket and not the injector Solved the bowel problem, working on the consonants...
3rd May 2016 8:58pm |
