Home > Puma (Tdci) > Puma 2.4L power steering fluid reservoir low - top up?
agentmulder
Kuwait
Gidday,
Just checked this, it's below the bottom mark on the 'dip stick' thingo - can I just top it up? If so, which fluid? (It's not the same as brake/clutch huh??)
If not, how to drain/bleed ?
Any tips appreciated
Post #527969 30th Apr 2016 6:11am
spudfan
Ireland
Top it up. Any decent power steering fluid or ATF will do. You need to check why the level of the fluid has dropped. Get underneath and look up towards the reservoir to try to spot if there is fluid visible. Run your fingers along the pipework to feel if there is any fluid on them. The usual culprit is a loose joint in the pipework from the reservoir that you can tighten. Had the same issue with my 2008 Puma and it was easily solved by tightening up a loose joint. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #528073 30th Apr 2016 2:16pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I had the same problem on a 2008 110, It took me a while to find, but as Spudfan says loose clip under the reservoir. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #528081 30th Apr 2016 3:36pm
agentmulder
Kuwait
Mine in 2008 (!)
OK, thanks for the infos - appreciated.
Going for Castrol power steering fluid.
ATF huh, so it's not like mixing orange juice and milk? If I had more time I'd like to learn more about the materials science going on with lubrication...
Post #528173 30th Apr 2016 9:19pm
