- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
MR_JAMES
just a quickie regarding the (wij500040) 5 micron fuel filter on the 2.4 and 2.2.
Doing some homework I learned ford fitted the 5 micron on the di engines, and a finer 2 micron to the tdci as the fuel system runs at a higher pressure.
Is there any reason why I can't fit the finer 2 micron filter to reduce muck passing into the pump and injectors? its a tiny bit longer than the land rover one but that doesn't matter in the grand scheme of things
https://www.fordpartsuk.com/shop/ford_tran..._c_567.htm
your thoughts? 1953 80"
1987 mini city e
2011 90"
29th Apr 2016 5:13pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
