Home > Technical > how do I remove the rear speaker pods (110)
Stacey007
Hello
Want to try and gain access to the reversing light and back of number plate plinth,
Got the trim apart around the small window and removed the black push fit screw holding the speaker pod in, but could not move it out of the way. Am I missing another connector or clip. Didn't want to keep pulling Smile
This bit...
Post #527544 28th Apr 2016 1:54pm
midlife
Ireland 2007 Defender 90 Puma 2.4 SW Rimini Red
there are 2 more under the carpet and it comes out sideways towards you and forward. Had to peel up carpet as you can feel the pod has a foot that goes under carpet
Post #527546 28th Apr 2016 1:59pm
mk1collector
I think they are stuck on at the top too Ray
My build thread
Post #527611 28th Apr 2016 7:00pm
Stacey007
Thanks both
Pretty sure by removing the little window surround its lose at the top but didn't know there was something at the carpet end.
Will have another luck, many thanks
Post #527616 28th Apr 2016 7:08pm
Jonnie421
Wales 2007 Defender 90 Puma 2.4 SW Tonga Green
Yes , lift up the rubber mat and find the screw , mine was stuck with double sided tape as well .
Thumbs Up Defender 90 Tonga green . My 2007 County .2.4Tdci puma .
Too many other Discos to mention, including a V8 petrol Disco3 and diesel Disco 3 !! ( All gone)
Post #527620 28th Apr 2016 7:28pm
