![]() | Home > Puma (Tdci) > New AP Clutch - Loose Springs - Video |
jwb Member Since: 30 Oct 2012 Location: Los Angeles Posts: 27 ![]() ![]() |
Hello all,
Just received a new AP Clutch (LR048731, dated 09.12.15) and 2 of the springs are very loose as shown video link below. 3rd spring freely spins but doesn't move side-to-side much. 4th spring is tight. How much spring movement is typical in the current revision clutch plate? My gut tells me to send it back. I went with the understanding that AP is same as Genuine. https://onedrive.live.com/redir?resid=758E...ideo%2cmp4 Cheers, Jason |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 ![]() ![]() ![]() |
Maybe it is genuine and maybe that's why they generally rattle. No doubt someone here will enlighten.
Shepherd Member Since: 21 Apr 2014 Location: Devon Posts: 22 ![]() ![]() ![]() |
Hi
I did mine a couple of years ago. Symptoms were the clutch rattled when the truck was warm and in neutral. When the clutch was dipped the noise stopped. When I stripped it out the old clutch springs were very loose and had warn the side of the housing. The springs were not as tight as I expected in the new clutch. Like yours, two were tighter than the other two. When I picked up the old clutch and shook it, it rattled but when I picked up the new clutch and shook it it did not. Obviously it's all subjective and it's a bit hard to tell from the video but I would say the play you have there seems excessive. As its a pain in the arse to fit I would say get it swoped before you go to all the effort of banging it back together. I would put a new slave cylinder in while your in there Hope that helps a bit |
http://www.defender2.net/forum/topic28321.html
My old thread |
Thanks Shepherd, I appreciate your insight. Mine is definitely a tambourine when I shake it (similar to the old one I took out), can't see how 2 of the springs would stay in place for very long. Frustrating to just swap it out and hope the next one's better. Maybe I can ask the vendor to give it a shake for me.
