Home > Puma (Tdci) > New AP Clutch - Loose Springs - Video
jwb
United States
Hello all,
Just received a new AP Clutch (LR048731, dated 09.12.15) and 2 of the springs are very loose as shown video link below. 3rd spring freely spins but doesn't move side-to-side much. 4th spring is tight.
How much spring movement is typical in the current revision clutch plate? My gut tells me to send it back. I went with the understanding that AP is same as Genuine.
https://onedrive.live.com/redir?resid=758E...ideo%2cmp4
Cheers,
Jason
Post #526911 26th Apr 2016 12:01pm
ter11
Switzerland 2007 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Hi all
As I myself will probably soon also need a new clutch, I am very interested to read some comments here... Anyone?
Regards
Ter
Post #527341 27th Apr 2016 4:32pm
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
Maybe it is genuine and maybe that's why they generally rattle. No doubt someone here will enlighten.
Post #527354 27th Apr 2016 5:36pm
Shepherd
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Hi
I did mine a couple of years ago.
Symptoms were the clutch rattled when the truck was warm and in neutral.
When the clutch was dipped the noise stopped.
When I stripped it out the old clutch springs were very loose and had warn the side of the housing.
The springs were not as tight as I expected in the new clutch. Like yours, two were tighter than the other two.
When I picked up the old clutch and shook it, it rattled but when I picked up the new clutch and shook it it did not.
Obviously it's all subjective and it's a bit hard to tell from the video but I would say the play you have there seems excessive.
As its a pain in the arse to fit I would say get it swoped before you go to all the effort of banging it back together.
I would put a new slave cylinder in while your in there
Hope that helps a bit
Post #527435 27th Apr 2016 9:26pm
Shepherd
Post #527439 27th Apr 2016 9:30pm
jwb
United States
Thanks Shepherd, I appreciate your insight. Mine is definitely a tambourine when I shake it (similar to the old one I took out), can't see how 2 of the springs would stay in place for very long. Frustrating to just swap it out and hope the next one's better. Maybe I can ask the vendor to give it a shake for me. Very Happy
Post #527467 28th Apr 2016 1:01am
