Home > Td5 > Wheel bearing kit
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Wheel bearing kit
As per the title, is there a wheel bearing kit which includes the bearings and new seals etc that you would fit when doing such a job? Or do I need to order separate parts? If it's all separate, can someone tell me what I should be looking to order - obviously bearings, paper seal, oil seal?? Cheers.
Post #525749 21st Apr 2016 3:15pm
Lionel
Australia
You haven't given us any information about what vehicle, year, model etc. Also whether front or rear bearings. Are you replacing or just cleaning & repacking?
We can give you information more easily if you provide a few facts.
In the meantime, you could check www.paddockspares.com as a starting point. They do sell kits, but I would suggest contacting them to see who makes their bearings. In the Britpart kits,the bearings are probably Chinese - at any rate they seem to be too cheap, so I would be enquiring as to whether they can supply Timken bearings, which are LR OEM.
Cheers,
Lionel
Post #526170 23rd Apr 2016 1:03pm
RoddyK05
My bad! Embarassed
It's a 2004 90, NSR wheel bearing to be replaced. I'd like to go genuine, and have to that end emailed Dan at Duckworth this morning to price me up. I really just wanted to know if there was a kit that contained everything or if I had to order separate items? Even knowing the correct names of the paper gasket and the oil seal would be a help so I know to get the right stuff. Thanks for your reply Lionel, it's appreciated Thumbs Up
Post #526178 23rd Apr 2016 1:44pm
Weston18
England 1999 Defender 110 300 Tdi DCPU Tonga Green
You would need-
Two bearings
Inner hub seal
Thrust washer
Lock washer
Two hub nuts
Drive flange gasket
Grease
Tools-
External circlip pliers
17mm socket and ratchet
52mm hub socket
Punch/chisel and hammer
13mm 12 sided socket
Cable ties
Manual dexterity
Hope that helps.
Post #526184 23rd Apr 2016 2:36pm
Retroanaconda
A Td5 will have the later single stake nut and selective spacer setup, not the adjustable two nuts setup. Unless it's been reverted to the earlier type (quite possible - many do as it's easier to set up in a home scenario). The information is in the parts catalogue, available online. Then just give the dealer a list of parts numbers.
No need to necessarily go genuine on wheel bearings, Timken ones are available from reputable resellers (Bearmach etc.), same goes for hub seals (Corteco/Gaco) and these are all safe OEM parts. I would go genuine for the gaskets though as most aftermarket ones tend to be very thin in my experience, same for the lock washer/staked nut as appropriate.
Post #526194 23rd Apr 2016 3:50pm
RoddyK05
Fantastic, exactly the information I was after- thanks all for the replies.
Post #526294 23rd Apr 2016 9:14pm
jonny2tanx
United Kingdom 2005 Defender 110 Td5 XS CSW Alveston Red
Kit to convert a TD5 bearing to the earlier type here
http://www.ebay.co.uk/itm/320894037819?ssP...1436.l2649
Post #526547 24th Apr 2016 10:35pm
miker
It doesn't take much to be fair. I stuck with the stake nut style because I'm lazy!
Also, I can't think of any reason why you couldn't just use a stake nut without a spacer?
Post #526557 24th Apr 2016 11:51pm
Don't do that.
The stake nut relies upon significant torque to keep it done up, the staking is not per se adequate. The two nut set-up relies upon the two nuts being tightened onto each other to provide the friction, with the staked washer as belt and braces.
Post #526579 25th Apr 2016 10:23am
miker
Ahh fair enough. I wasn't going to do it, just mulling the thought over!
Post #526582 25th Apr 2016 10:38am
Lionel
Australia
There are varying opinions on whether to use stake type nut with spacer, or to revert to the double adjuster nut with lock tab when replacing a bearing with a new one.
Theoretically, bearing tolerances are tight enough to still be able to use the original size spacer, particularly if you are using the same make of bearing. Changing a worn out hub for a new one though, is a different matter!
I have seen a few postings which have described preload problems trying to use the original spacer with the stake nut system when bearings have been changed, so I would go carefully when refitting. If it was me, I would get a conversion kit as well - just in case - as they are pretty cheap. The adjustable system is preferable for the home mechanic IMHO, & makes it much easier to keep the bearings in good adjustment over the longer term.
Cheers,
Lionel
Post #527204 27th Apr 2016 2:46am
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Anyone have a rough idea of size of Circlip Pliers?
Post #569843 10th Oct 2016 11:18am
miker
Reasonably big? It's to get the circlip of the end of the half shaft, and it's a sturdy Censored !
Also possible to see just by whipping a wheel off/centre cap.
Post #572414 21st Oct 2016 12:26am
