![]() | Home > Technical > Whats it for ? |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
?? A picture may help ??? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
Alex e Member Since: 23 Apr 2007 Location: Home isn't it Posts: 204 ![]() ![]() ![]() |
do you mean the tube steering guard thingy? if a plate is not fitted, it's a tube.
Alex,prob mate,just wondered why they're not on a 90 2.4 90 XS
mse Member Since: 06 Apr 2008 Location: UK Posts: 5086 ![]() ![]() ![]() |
They are an option on both the 110 and 90 - a £90sh option ISTR The are the underride protection bar - a scafolding type tube spanning the width of the chassis with a v bar that connects to the chassis, sitting just infront of the steering rod. Mike |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
It also appears to be made out of steel tube as soft as toilet paper rolls. It only took me 2 weeks to bend my one
![]() Tim |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 ![]() ![]() ![]() |
I replaced the same item on the Disco with an after market thicker walled version.
I regard it as being a disposable item like a tissue.... use it and throw it away after it has done its job Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
Thanks all. 2.4 90 XS
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Mine a 110 have it
Some times this pieces are designed like a fuse to not damage other parts like the wear sleeves in some machines. Replacing it for a heavy one could be a problem transfering the possible damage to another more expensive parts. (just a though). Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
changill Member Since: 13 Dec 2008 Location: North West - Preston/Lancaster Posts: 27 ![]() ![]() ![]() |
Get a proper Steering Guard Fitted!!! Only Alcohol Can Save me Now
Nanocom Available in the North West |
