Home > In Car Electronics > WANTED Review - GRP 4x4 LED headlights
jackp
United Kingdom 2009 Defender 90 Puma 2.4 PU Stornoway Grey
Hi all,
Just wanted to know If anyone is using these LED headlights? looking to upgrade but cant justify JW's.
http://www.grp4x4.com/land-rover-defender-...ht-20.html
I like the 4 LED lamp style that these have but don't really know any more about the LED upgrade as a whole. As far as I can understand with out a DRL they are literally plug and play. and they will increase my light emitted to the road. Seems like a fairly good price as well.
A friend of mine bought a Light bar from them and it had condensation - they replaced it with a new version pretty much overnight so not worried about the company just want a honest review on the lamps them selves.
Any opinions would be useful cheers.
Post #524217 15th Apr 2016 1:02pm
Cupboard
I have never experienced them, but one thing that makes me a little wary is this statement:
Quote:
An output of 28W on low beam, and 50W on high means these lights are bright and powerful
Light output is measured in lumens, electrical power is watts. So they're saying that the lights are bright because they use a certain amount of electricity, which is not correct logic.
They might be fine but you have no way of comparing them to any other light.
The light output depends on the efficiency of the LED driver circuit, the efficiency of the LED and the efficiency of the optics. Most people will quote a lumens figure for the LED output, (raw, theoretical, calculated, or a few other names) and a second, lower, figure for the output of the whole assembly (actual, measured, and other names). Saying "this is good because it uses 28W" is like saying "my vehicle is great offroad because it uses twenty litres of diesel per hour".
Edit: Another thing against them is you can get the well respected Trucklites for only another £11 from here: http://www.defender2.net/forum/topic37882.html and the Trucklites have a higher IP rating.
Post #524430 16th Apr 2016 9:55am
jackp
Exactly the sort of info I was after. Shame as I like the 4 spot lamp style with no DRL/halo.
I will email GRP 4x4 and ask for these figures, and then compare against the market rivals (JW and Trucklite)
Thanks again
Post #525027 18th Apr 2016 3:01pm
Cupboard
At the lower end of the price range you've also got the Britpart Lynx Eye ones, and at the JW Speaker end of the price range there are the Noldens too.
Post #525030 18th Apr 2016 3:20pm
jackp
In case any one was interested the GRP 4x4 style lights as pictures are raw lumen 2610 full beam and 1770 low beam.
I still really like this style - anyone know the standard light strength from the defender units.
Post #525276 19th Apr 2016 12:39pm
Lost for Words
An H4 bulb is 1650/1000lm (but, of course, that's not the full picture). Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #525357 19th Apr 2016 6:13pm
Cupboard
So raw dipped lumens is a little lower than the Noldens, and raw full beam is a little higher.
Then it's all down to the quality of the optics Smile
Post #525423 19th Apr 2016 9:02pm
leeds
Raw lumens is the calculated theoretical light output of a LED headlight.
Effective lumen output is a better measure of light output as it is the calculated raw lumen output minus theoretical losses.
Measured lumen output is the most useful light output figure.
The other figure you should be looking at is the IP rating. IP67 (IMO) is the minimum water protection whereas the best IP rating is IP69K
Brendan
Post #525426 19th Apr 2016 9:20pm
jackp
Thanks for all your help, I'm going to keep looking at other styles for the time being.
Post #525605 20th Apr 2016 7:48pm
g-mack
i think the flat dog ones have good reviews from a few members on here! My 109 thread
my youtube channel
Post #525630 20th Apr 2016 9:03pm
Cupboard
Of course they might be great headlamps just without the premium price. Such things do exist.
I think it just helps to go in to anything with your eyes open.
Post #525679 21st Apr 2016 7:16am
tomdaprince
Netherlands 2007 Defender 90 Puma 2.4 HT Tonga Green
I have the GRP lights and I am extremely pleased with them. Have had them for about a year now and issue free. Lamp construction is very solid, no condensation issues and the light pattern is just perfect, which says a lot for a LED headlight as most (Even the premium brands) look like your pointing a flashligt at the ground.
Absolute recommendation, splendid company to deal with to!
Post #525876 22nd Apr 2016 6:49am
jackp
Thanks for your info Tom!
Still looking around but to be honest I cant find anything I like the look of as much as these 4 spot GRP versions.
Post #526872 26th Apr 2016 10:30am
Cupboard
Well why don't you buy them and review them for us? Smile
Post #526899 26th Apr 2016 11:39am
