Home > Camping, Caravanning and Holidays > Roof tent recommendations
Page 3 of 3 <123
muddybaldboy
Wales 1999 Defender 110 Td5 HT Chawton White
I do on solo trips Thumbs Up He who dies with the most toys...wins!
Post #524387 16th Apr 2016 7:16am
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
How do people fix there tents to the rack. My new rack is very close to the roof and my fat arms can't put the nuts on the clamps so working on a rack to fit the rack so I can clamp at the edges but someone has to have a better idea than me
Post #524790 17th Apr 2016 5:49pm
leeds
Which rack is it Sphere?
I can just get my arms under a Patriot roof rack to do the nuts up. A bit on the painful side at times!
Alternative is to undo all the roof rack clamps then get some levers such as 4 x 2 timber and raise the roofrack up so you can get your arms underneath. Coome.
Consider some thin ply on the roof to prevent damage to the roof.
The easiest solution is undo roof rack and lift it clear off the vehicle, either with a few bodies to assist around or an electric hoist however not always easy to do at home.
Brendan
Post #524798 17th Apr 2016 6:21pm
Sphere
It's a mcb4x4 rack so a tubular rack. I use to use two rhino bars and then used a fork lift to put on and off. Worked super but needed a couple of eyes to watch the roof. Upgraded to a full rack this year so I can use it for other things so the tent will be on and off quite a bit (forklift makes light work of removing it)
So my idea is bolting the tent to two lengths of box (basically two roof bars) and these I can clamp in a similar way to the edge of the rack where I can reach and get a socket on.
Post #524801 17th Apr 2016 6:32pm
leeds
Hi Sphere, I am not familiar with your rack.
However if you have a forklift available then the job is easier
Would suggest you incorporate some eyebolts at each end of the bar. Makes attaching slings just that bit easier. Just ensure that your bars are of decent size.
Brendan
Post #524847 17th Apr 2016 9:09pm
YOLO110
Australia
Vogler wrote:
We have a James Baroud Discovery Espace Evolution since 2013...
My GF can't close the tent on her own. To successfully close it, you have to stuff the fabric on top of the rear 'legs' while keeping the tent closed but for one feet or so. Always close the front first, then the back.
Hi Joris,
Just read this post... I recently bought a camper trailer with a Espace Evolution fitted.
The previous owner's GF had the same issue...
Solution... he fitted a long 'loop' strap, fastened on either side of the rear of the 'roof' which then hangs down from the rear elevated side. Just grab hold of this at head height and pull it down. He has fitted a hook on the trailer so when the roof is nearly down after pulling, the loop goes under the hook which then holds the tent down against the gas strut pressure. Then it's much easier to just hook up the 4 straps, as you say front one's first and off you go!
Works great! Thumbs Up YOLO... You Only Live Once...
Post #524864 17th Apr 2016 10:01pm
Seabreeze
England 1996 Defender 90 300 Tdi CSW Epsom Green
You will have masses of space in the 1.6m! My delivery took nearer 3 weeks, but the delay was something do with the U.K. End of the logistics company. I would be interested to hear from you once you have tried it, I am sure you will be happy with the quality.
Post #524895 18th Apr 2016 12:04am
johnnyd
I'm after a tent now also, roof or floor for a 90 SWB
JD 2008 TDCi 2.4 XS CSW
Post #530029 8th May 2016 10:49pm
muddybaldboy
I had a couple of nights in the gordigear last weekend-best nights I've ever slept in any tent!
Build quality is fantastic.
As Seabreeze said, tons of space.
Long term plan, the 3 children will be sleeping in this one (mounted on modded Sankey) and I'm going to be ordering a 1.4m version for the 110 for the grown ups Thumbs Up
Highly recommended He who dies with the most toys...wins!
Post #530033 8th May 2016 11:19pm
jrharte
United Kingdom 2000 Defender 90 Td5 X-Tech LE Zambezi Silver
Quote:
That looks awesome! Pity we always camp with the dog though. She'd go nuts if she wasn't in the tent with us.
Post #530069 9th May 2016 11:14am
Page 3 of 3 <123
