Home > Maintenance & Modifications > Webaosto Wiring
Andy W
Webaosto Wiring
Hi, I have just purchased a Webasto Thermo Top Z/ C-D from a Rover 75 to fit into my vehicle. I have read numerous articles about the Webasto heaters and that some are tied into the vehicle ECU, however the ones in the Rover 75 are not. So the heater arrived today in a box, but no wiring harness, the plugs are still attached but the wires have been cut!
So my question is, is anyone able to help with where the three wires on the X1 plug connect to; I am guessing that one is to turn it on and off, another is to the dosing pump and the third possibly for diagnostics?
On my unit the pins on the X1 plug are as follows:-
1 - Green/White
2 - Red/White
3 - Not used
4 - Not used
5 - Not used
6 - Brown/White
Thanks, Andy
Post #507660 24th Feb 2016 4:22pm
dgardel
Italy
page 29 (physical, not page printed no.) of this DOCUMENT
also look at THIS ONE
for the diagnostic (but you need to buy the interface on EBAY) follow this LINK
and if you have time, tons of documents HERE
Thumbs Up Thumbs Up Thumbs Up
By the way
X1 - pin 1 if HIGH (from+ 5,0V to +13,6V -> heater ON; if at 0V or grounded, -> heater OFF
X1 - pin 2 is for the diagnosis
X1 - pin 3 - external thermostat (heater doesn't switch on if ext temp is > of....thermostat dependent) - DO NOT USE!
X1 - pin 4 is for switch on the cabin fan (when coolant arrive at 48 �C)
X1 - pin 5 - summer/winter switch - DO NOT USE!, if you use a remote, in summer you can switch on the cabin fan switching on the heater (no flame, only fan)
X1 - pin 6 - Dosing pump (+)
other connectors pinouts on the pic.
Harness is important, I suggest you to buy THIS ONE ready to install the TIMER (1531 or 1533 IMHO the first is better)
HERE the link for the 1531 timer
Daniele
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #508900 28th Feb 2016 1:35am
dgardel
Italy
Also see here
http://www.defender2.net/forum/topic14319.html?highlight=webasto
http://www.defender2.net/forum/topic10368.html?highlight=webasto
and REMEMBER TO INSTALL the little no-return valve as showed below to avoid air bobble in the cooling circuit
RED arrow is the flow direction
IID Pro MV License
Post #508902 28th Feb 2016 2:07am
dgardel
Italy
My car has the remote T91 and the 1531 timer installed, it is a pleasure to switch ON the heater from home 15 minutes before using the car.....
and, using the timer, I decide how many mins the heater must be switched ON
the remote control has a range of 100-300 meters (1km outdoor) personally tried!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #508903 28th Feb 2016 2:13am
dgardel
Italy
My 1531 Timer installation
WEBASTO 1531 USER MANUAL
IID Pro MV License
Post #508906 28th Feb 2016 2:28am
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Re: Webaosto Wiring
1 - Green/White
2 - Red/White
3 - Not used
4 - Not used
5 - Not used
6 - Brown/White
Thanks, Andy
Is this true?
Should I be looking for a Thermo Top Z C/D Rover 75 Webasto heater for my 2003 td5?
Are there any other "used models" that can be controlled independently from the vehicle ECU for a TD5 using the controller Tig up linked to?
Patrick
Post #524494 16th Apr 2016 3:24pm
dgardel
Italy
or look inside here
https://onedrive.live.com/redir?resid=4BC2...lder%2cpdf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #524559 16th Apr 2016 7:31pm
dgardel
Italy
Re: Webaosto Wiring
1 - Green/White COMAND FOR HEATER ACTIVATION/DEACTIVATION
2 - Red/White DIAGNOSIS via Webasto SW
3 - Not used
4 - Not used
5 - Not used
6 - Brown/White to the dosing pump (12 V pulsed)
Thanks, Andy
again
X1 - pin 1 - COMAND FOR HEATER ACTIVATION/DEACTIVATION (if HIGH, from+ 5,0V to +13,6V -> heater ON; if at 0V or grounded, -> heater OFF)
X1 - pin 3 - DO NOT USE!
X1 - pin 4 - is for switch on the cabin fan (when coolant arrive at 48 �C out 12V for drive a relay for the cabin fan)
X1 - pin 5 - summer/winter switch, if you use a remote, in summer you can switch on the cabin fan switching on the heater (no flame, only fan)
and
X2 - pin 1 - +12V from battery fused
X2 - Pin 2 - GROUND
I suggest you to buy a compatible harness
http://www.ebay.it/itm/webasto-thermo-top-...SwlV9WTjCk Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #524565 16th Apr 2016 7:59pm
