Home > Maintenance & Modifications > Webaosto Wiring |
page 29 (physical, not page printed no.) of this DOCUMENT
also look at THIS ONE for the diagnostic (but you need to buy the interface on EBAY) follow this LINK and if you have time, tons of documents HERE By the way Click image to enlarge X1 - pin 1 if HIGH (from+ 5,0V to +13,6V -> heater ON; if at 0V or grounded, -> heater OFF X1 - pin 2 is for the diagnosis X1 - pin 3 - external thermostat (heater doesn't switch on if ext temp is > of....thermostat dependent) - DO NOT USE! X1 - pin 4 is for switch on the cabin fan (when coolant arrive at 48 °C) X1 - pin 5 - summer/winter switch - DO NOT USE!, if you use a remote, in summer you can switch on the cabin fan switching on the heater (no flame, only fan) X1 - pin 6 - Dosing pump (+) other connectors pinouts on the pic. Harness is important, I suggest you to buy THIS ONE ready to install the TIMER (1531 or 1533 IMHO the first is better) HERE the link for the 1531 timer Daniele Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 28th Feb 2016 1:26am. Edited 6 times in total |
28th Feb 2016 12:35am |
Also see here
http://www.defender2.net/forum/topic14319.html?highlight=webasto http://www.defender2.net/forum/topic10368.html?highlight=webasto and REMEMBER TO INSTALL the little no-return valve as showed below to avoid air bobble in the cooling circuit RED arrow is the flow direction Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
28th Feb 2016 1:07am |
My car has the remote T91 and the 1531 timer installed, it is a pleasure to switch ON the heater from home 15 minutes before using the car.....
and, using the timer, I decide how many mins the heater must be switched ON the remote control has a range of 100-300 meters (1km outdoor) personally tried!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 28th Feb 2016 1:30am. Edited 1 time in total |
28th Feb 2016 1:13am |
My 1531 Timer installation
Click image to enlarge WEBASTO 1531 USER MANUAL Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
28th Feb 2016 1:28am |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 |
Is this true? Should I be looking for a Thermo Top Z C/D Rover 75 Webasto heater for my 2003 td5? Are there any other "used models" that can be controlled independently from the vehicle ECU for a TD5 using the controller Tig up linked to? Cheers Patrick |
16th Apr 2016 2:24pm |
Click image to enlarge Click image to enlarge or look inside here https://onedrive.live.com/redir?resid=4BC2...lder%2cpdf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
16th Apr 2016 6:31pm |
again Click image to enlarge X1 - pin 1 - COMAND FOR HEATER ACTIVATION/DEACTIVATION (if HIGH, from+ 5,0V to +13,6V -> heater ON; if at 0V or grounded, -> heater OFF) X1 - pin 2 is for the diagnosis X1 - pin 3 - DO NOT USE! X1 - pin 4 - is for switch on the cabin fan (when coolant arrive at 48 °C out 12V for drive a relay for the cabin fan) X1 - pin 5 - summer/winter switch, if you use a remote, in summer you can switch on the cabin fan switching on the heater (no flame, only fan) X1 - pin 6 - Dosing pump (+) and X2 - pin 1 - +12V from battery fused X2 - Pin 2 - GROUND I suggest you to buy a compatible harness http://www.ebay.it/itm/webasto-thermo-top-...SwlV9WTjCk Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
16th Apr 2016 6:59pm |
