Home > Maintenance & Modifications > TD5 Bulkhead repairs/options
excossack
My bulkhead has got a rust patch that needs repairing. (Under the windscreen and across above the vent)
Purchased a few bits i.e repair panel, windscreen frame, seals etc.
Popped into see the body shop chap whom I had spoke to around 8months ago about doing the work.
He was honest enough to say, not done a bulkhead repair before and he wasn't sure if he wanted to do the job but had a look around anyway.
Rough suggestion of work required:
Roof off or at least undone enough to remove the windscreen frame
Windscreen frame off (to be replaced)
Door off on passenger side
Bonnet off
Passenger wing off
Remove spot welds for water channel across the bulkhead
Remove spot welds for the bonnet hinge
Remove wipers
Possible removal of dash & associated trim.
At this point other nasties could be revealed that I can't see hiding behind the dash.
Options as I see it;
1. Repair existing bulkhead
2. Replace bulkhead (Having gone through the process above, how far off am I?
3. Ignore the rust
4. Replace Defender with a newer model/Disco
Looking around TD5 bulkheads are not cheap, Puma ones are cheaper but how much work is involved in fitting a Puma bulkhead to a TD5, and more importantly, how difficult is it fit a TD5 dashboard to a Puma bulkhead.
Buying a 2nd hand bulkhead is an option, repair any rust, treat, prime, paint & fit along with remaining parts. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #524416 16th Apr 2016 9:04am
Fatboy Slim
Wales
I would go second hand bulkhead myself.
Post #524421 16th Apr 2016 9:18am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
My son successfully fitted a Puma bulkhead to his 2001 Tombraider, pretty straightforward as I remember, just means loss of opening dash vents.
Post #524436 16th Apr 2016 10:09am
excossack
Thanks Clive.
How did you son get on with things like screw holes for the dash, gear stick location etc
Loss of flaps.....could live without, would be one less draught and one less leak I suppose 1999 Defender TD5 110
Regards
John M0VAZ
Post #524521 16th Apr 2016 3:58pm
Clive
I'm not so sure about the details TBH, it was a while ago and I wasn't really involved, I can ask him though and report back.
As far as I know, the gear levers would only be a problem if you were planning to fit the entire Puma dash, I think the engine and gearbox is mounted a little further back on the Puma, or maybe it's just a longer bellhousing, either way it shouldn't be a problem if only using the Puma bulkhead itself into a Td5.
Post #524538 16th Apr 2016 4:51pm
excossack
I was only thinking of fitting the bulkhead and the TD5 dash.
If you could probe for more info that would be a great help. 1999 Defender TD5 110
Regards
John M0VAZ
Post #524546 16th Apr 2016 5:34pm
DOOFER
I'm now doing a puma bulkhead into a 300tdi. the transmission tunnel required some fettling as they are totally different. so be prepared for a little welding. i cut the section i needed out of my old bulkhead and grafted it in. used loads of dinitrol in the process. the dashboard if also different but I got round the mounting points by inserting rivnuts where required.
I never used the vents and it's one less place to rust now. DON'T PANIC
Post #524625 16th Apr 2016 9:32pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
If you are keeping the car for a long time, then a new replacement bulkhead is the way to go, IMHO Thumbs Up
Post #524628 16th Apr 2016 9:49pm
Clive
Had a chat with the lad earlier, he said he had to alter the Puma bulkhead around where the Td5 bell housing tunnel goes to make it fit properly, had to open it up a bit and then seal it with tiger seal, also the fittings for the clocks is a bit different so that needed modifying too, all in all no great drama though and nothing that couldn't be achieved with basic hand tools and a bit of common sense.
Post #524879 17th Apr 2016 9:52pm
excossack
Thanks Clive. Now I just need to decide what route to take.. 1999 Defender TD5 110
Regards
John M0VAZ
Post #524935 18th Apr 2016 7:28am
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
I read somewhere a guy fitting a puma dash used the disco selector turret and this cleared the puma dash. Moved the hi lo to behind the gear selector.
Post #525040 18th Apr 2016 3:42pm
excossack
After much pondering, I am going to go for a Td5 bulkhead and get the bulkhead replaced.
I have had various prices for the job, the most has been £3500 which included a new TD5 bulkhead and 3 weeks work
A few garages have been a straight no - don't want to touch the job.
The last garage I went to said yup, we can do that and estimated a weeks work.
So next is a decent bulkhead from a breaker then either;
a) shot blast
b) acid dip (somewhere like SPL?)
c) leave as is and rub down & repaint 1999 Defender TD5 110
Regards
John M0VAZ
Post #528974 4th May 2016 7:22am
Mo Murphy
But yourself a mig welder and learn to weld. You will never face this dilemma again.
50 Shades of Pennine Grey
Post #529035 4th May 2016 11:00am
excossack
I have a mig but do not feel confident enough to do a good enough job and what also concerns me is the amount of rust inside the bulkhead I can not see. Plus I would rather be working in a garage than in my drive with no cover especially if get to a point where I have no doors, bonnet etc on the LR. 1999 Defender TD5 110
Regards
John M0VAZ
Post #529037 4th May 2016 11:11am
Disco_Mikey
A new Td5 bulkhead is surprisingly well priced, and the best basis for rustproofing for the future , especially if unseen rust is going to be a concern Thumbs Up
Post #529054 4th May 2016 1:07pm
