Home > Maintenance & Modifications > TD5 Bulkhead repairs/options |
1978 Member Since: 04 Aug 2015 Location: Lancashire Posts: 519 |
In your situation I would go for a new bulkhead and have it galvanised before painting.
4th May 2016 1:12pm |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
They can do better than that, even for a genuine part
4th May 2016 3:13pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5873 |
Apologies, that was not direct from a dealer that was an after market supplier. 1999 Defender TD5 110
4th May 2016 3:50pm |
A genuine LR bulkhead can be sourced cheaper than that
4th May 2016 3:53pm |
gabe3105 Member Since: 25 May 2015 Location: Grimsby Posts: 237 |
These guys are advertising galvanised bulkheads for £995 + VAT....
http://www.ashtreelandrover.com/Pricelist.html I've no experience of them though |
4th May 2016 3:54pm |
I have done some calling around and I can get a 2nd hand bulkhead stripped/dipped to remove rust/paint/filler for around £175+VAt and then Zinc coated for around £60 which could be an option 1999 Defender TD5 110
5th May 2016 3:11pm |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 |
It's one of those jobs you want to save to when you need to repair/replace the chassis aswell. I had my rear crossmember done and the front outriggers. Now the bulkhead is developing holes. Wish it had happened together as I would have put a galv chassis and bulkhead on at the same time!!
5th May 2016 4:29pm |
Do you want to buy a bulkhead with me and try and get discount....? 1999 Defender TD5 110
5th May 2016 5:29pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Any links to a cheap td5 bulkhead disco? i can see a New puma bulkhead on e bay for £760..and £860 galvanised! |
5th May 2016 5:31pm |
Doing the maths, I think a new one will work out better value
2nd hand bulkhead £800 (internal condition unknown) Travel £30 Dip/strip £175+vat Travel £60 (trip there/trip back & trip there/trip back a week later to collect) Zinc coat £70 with travel and tunnel cost (assuming no repairs are needed after dip/strip) £1170 With the original bulkhead lasting 15 years then a new one will last just as long after painting and copious amounts of Dinitrol cavity wax injected before fitting and then more later on in life. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
5th May 2016 6:40pm |
are you doing the swap yourself ?if your paying a garrage i personally agree with 1978 and would get the new bulkhead stripped and galvanised..the extra £200 would be drowned in the labour costs of he swap and would improve your resale value..if you ever sell that is!anyway good luck!and post a few photos
5th May 2016 8:45pm |
The swap is being done by a local garage. I was considering doing it myself but cant have the car tied up for two weeks while I do the work. Doubt I could get it done in weekend 1999 Defender TD5 110
5th May 2016 8:57pm |
