Home > Maintenance & Modifications > Dirty rear windows |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
Corroded Block-fixing-catch slide window very easy to replace you need part number depending on age of the vehicle
To (V) 1A 621960 From (V) 1A 621961 As for the muck and green stuff that is not so easy to get at unless you take the windows apart (not a five minute job) I have found that if you use a long thin screwdriver with bits of cloth wound round the blade you can clean most of the gunk out of the space. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
14th Apr 2016 2:35pm |
blimbug Member Since: 17 Mar 2016 Location: Wiltshire Posts: 92 |
Thanks for the response.
Sorry for a new'b question, but where would you generally recommend purchasing replacement parts? is the dealership the only place, or is there a land rover specific auto factors? Thanks! |
14th Apr 2016 2:57pm |
or sit sponsors duckworthparts
to 1A MUC1704 from 1A CPK000010 seal for same CPT000010 |
14th Apr 2016 3:01pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Paint brush and APC,All Purpose Cleaner (let it soak to kill the moss)usually found under the sink,or buy Stardrops,Flash,Tesco's own Daisy. Pov.spec,ftw. 2006, 110,TD5.
14th Apr 2016 5:30pm |
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1032 |
I used to use something like this on my old 110
http://www.lakeland.co.uk/4751/Track-Clean...14205611:s |
14th Apr 2016 8:57pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
I use moss killer from the garden centre. Spray on and just leave it.. it will die and then just brush off the residue with a clean toothbrush.
As for the corroded bracket, just unscrew it, reface it with a brush / sandpaper and respray with etch primer & a black paint of your choice. 1953 80" 1987 mini city e 2011 90" |
15th Apr 2016 10:20am |
