Home > Maintenance & Modifications > Dirty rear windows
blimbug
United Kingdom 2009 Defender 110 Puma 2.4 SW Bonatti Grey
Dirty rear windows
Hi all,
The cleaning and fettling continues!
A couple of questions that I hope someone could answer.
Firstly, whats the best way to clean the rear windows. As per the picture, there is allot of green moss/sediment build up that I'd like to get rid of. Is there any way to easily remove the rear window panes, or do i have to clean them in situ?
Secondly, is there any way to replace this dilapidated fixture on the outside of the window?
Thanks
Post #523891 14th Apr 2016 12:42pm
gilarion
Corroded Block-fixing-catch slide window very easy to replace you need part number depending on age of the vehicle
To (V) 1A 621960
From (V) 1A 621961
As for the muck and green stuff that is not so easy to get at unless you take the windows apart (not a five minute job)
I have found that if you use a long thin screwdriver with bits of cloth wound round the blade you can clean most of the gunk out of the space. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #523910 14th Apr 2016 2:35pm
blimbug
Thanks for the response.
Sorry for a new'b question, but where would you generally recommend purchasing replacement parts? is the dealership the only place, or is there a land rover specific auto factors?
Thanks!
Post #523915 14th Apr 2016 2:57pm
dorsetsmith
or sit sponsors duckworthparts
to 1A MUC1704 from 1A CPK000010
seal for same CPT000010
Post #523916 14th Apr 2016 3:01pm
jimbob7
Paint brush and APC,All Purpose Cleaner (let it soak to kill the moss)usually found under the sink,or buy Stardrops,Flash,Tesco's own Daisy. Pov.spec,ftw. 2006, 110,TD5.
Post #523958 14th Apr 2016 5:30pm
stanley
I used to use something like this on my old 110
http://www.lakeland.co.uk/4751/Track-Clean...14205611:s
Post #524038 14th Apr 2016 8:57pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I use moss killer from the garden centre. Spray on and just leave it.. it will die and then just brush off the residue with a clean toothbrush.
As for the corroded bracket, just unscrew it, reface it with a brush / sandpaper and respray with etch primer & a black paint of your choice. 1953 80"
1987 mini city e
2011 90"
Post #524158 15th Apr 2016 10:20am
