Home > In Car Electronics > What rear camera for Alpine ine-920r
N16kct
United Kingdom 2010 Defender 110 Puma 2.4 USW Corris Grey
I've just bought myself an alpine double din ine-920r for my 110. I'm looking at camera's, but I'm not sure what do go for?
I'd like the best I can get, but I don't know which to buy or at what point I'm wasting money as the camera features more than the HU can support?
I'd like to stick with alpine and have been looking ad the c155 and c252rd.
Also placement wise what have people done? Does it get dirty quickly?
Thanks in andvance
Post #523823 14th Apr 2016 9:18am
Furball
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
N16kct, The camera placement depends to a certain degree on which camera you go for.
I used a wide'ish (I think it was 120°) angle camera which was a dome shape about 22mm (without going outside to measure it). I mounted it under the number plate light by drilling a small hole underneath and feeding the wires in using the same route as the cables for the number plate light - so no drilling and the resistance to weather is already there. It doesn't get dirty or wet which is weird. During winter i did wipe it once or twice but that was mainly cause I was at the back of vehicle I thought I'd do it whilst i was there and not through necessity.
I found that this give you a view across the car and better for judging distance or gap between you and the object your trying to park near.
I've seen many photos online where people replace the washer jet with a camera and relocate the washer jet. The problem with this is the spare wheel may obscure the view.
If you want, I can take a photo of the camera and the view on the screen if that would help?
Post #523909 14th Apr 2016 3:35pm
N16kct
That'd be brilliant thank you!
That's the main concern for me, I had thought about motorising the camera, In order for it to park in under cover to stop it from getting dirty. But if its fine placed there, then it saves me a fair amount of work Thumbs Up
Post #523913 14th Apr 2016 3:44pm
Furball
Hi N16kct, pictures attached (if I've done it correctly).
The camera was available in standard and reverse for £15/£20, so I bought 2 and kept one as a spare - just in case.
Post #523953 14th Apr 2016 6:14pm
N16kct
Id say thats decent enough Thumbs Up i wonder wether the alpine kit needs to be centrally positioned for the visual markers to work or not ?
Other than that I like that, well hidden!
Post #523956 14th Apr 2016 6:22pm
Furball
You mention that you have started to look at cameras, what I would say is that the 'markers/guides' would be static for an aftermarket camera unless they have developed some sort of module that attaches to the steering. So in theory yes, the camera would need to be central.
If you want, I can dig out the suppliers details of the camera i bought. It uses a standard RCA/Phono connection.
Post #523964 14th Apr 2016 6:53pm
N16kct
Thank you very much for taking the time to take those Thumbs Up
I think I've made a decision non the .camera, I wanted to keep the brand's the same as I'm odd like that Laughing and also the image quality is supposed to be good. But to be honest anything is better than nothing in a 110 utility!
Post #523970 14th Apr 2016 6:59pm
Furball
No problem, and good luck fitting it.
Post #523971 14th Apr 2016 7:00pm
N16kct
I'll post up pics once I've done it, thank you Thumbs Up
Post #523976 14th Apr 2016 7:10pm
mickygee
Australia 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
i see a problem with the rear camera placement. when reversing at night the glare from the number plate light makes it very hard to see clearly. ask me how i know...
Post #524060 14th Apr 2016 10:43pm
Furball
I think we know the answer to that Wink
Its not a problem on mine, only when the indicator flashes.
Post #524063 14th Apr 2016 10:47pm
