Home > In Car Electronics > Cluster illumination for tdci? Green to white?
N16kct
United Kingdom 2010 Defender 110 Puma 2.4 USW Corris Grey
Can you change the colour of the lighting on the tdci clocks? Are they filtered?
I'm going to install my ultragauge into the clocks, I was thinking as I'm going for white foils from alive it'd look better to have white illumination and I don't have to mess about with trying to filter the UG screen!
Post #523860 14th Apr 2016 12:33pm
They are filtered green, only changing filters can change the colour.
Post #523862 14th Apr 2016 12:43pm
N16kct
Are they removable? I could probably get replacements cut at work if they are and fit some new leds
Post #523864 14th Apr 2016 12:49pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I did look into this too, but seemed to be a whole lot of hassle?
I ended up filtering the UG screen, which was far easier. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #523878 14th Apr 2016 1:15pm
N16kct
I've searched for images of the clocks split down but not had much luck, if the green filters are removable then I can manufacture clear ones at work with ease.
Post #523883 14th Apr 2016 1:24pm
They are spot hot melted IIRC.
With the clock it would need to be taken apart first to see, pretty sure no one has taken it apart.
Not that I have heard of anyway
Post #523904 14th Apr 2016 3:12pm
N16kct
Sounds fairly straight forward then, drill off old screens, glue new ones on, change bulbs?
Post #523905 14th Apr 2016 3:19pm
It has definitely been done on the centre dash so I don't see a problem.
Give it a go. Thumbs Up
Post #523906 14th Apr 2016 3:25pm
N16kct
As far as leds go do you have any suggestions? I think I'll get a spare set and take them to work next week Thumbs Up
Post #523907 14th Apr 2016 3:29pm
Well I much prefer SMD chip style LED's but I'm not sure if you'll find them suitable for this application.
Post #523912 14th Apr 2016 3:43pm
N16kct
May struggle for space with those, I'll have a play and post my findings
Post #523914 14th Apr 2016 3:48pm
N16kct
Having looked into this a lot more, I'm going to take the easy way out and use green filters over the ultragauge as I'm going to fit the check temp in the clocks as well and that doesn't illuminate white sadly, everything must match!! Laughing
Post #524448 16th Apr 2016 12:06pm
