Home > In Car Electronics > Cluster illumination for tdci? Green to white? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20281 |
They are filtered green, only changing filters can change the colour.
14th Apr 2016 11:43am |
N16kct Member Since: 24 Aug 2015 Location: Oxfordshire Posts: 151 |
Are they removable? I could probably get replacements cut at work if they are and fit some new leds
14th Apr 2016 11:49am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
I did look into this too, but seemed to be a whole lot of hassle?
I ended up filtering the UG screen, which was far easier. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
14th Apr 2016 12:15pm |
I've searched for images of the clocks split down but not had much luck, if the green filters are removable then I can manufacture clear ones at work with ease.
14th Apr 2016 12:24pm |
They are spot hot melted IIRC.
With the clock it would need to be taken apart first to see, pretty sure no one has taken it apart. Not that I have heard of anyway |
14th Apr 2016 2:12pm |
Sounds fairly straight forward then, drill off old screens, glue new ones on, change bulbs?
14th Apr 2016 2:19pm |
It has definitely been done on the centre dash so I don't see a problem.
Give it a go. |
14th Apr 2016 2:25pm |
As far as leds go do you have any suggestions? I think I'll get a spare set and take them to work next week
14th Apr 2016 2:29pm |
Well I much prefer SMD chip style LED's but I'm not sure if you'll find them suitable for this application.
14th Apr 2016 2:43pm |
May struggle for space with those, I'll have a play and post my findings
14th Apr 2016 2:48pm |
Having looked into this a lot more, I'm going to take the easy way out and use green filters over the ultragauge as I'm going to fit the check temp in the clocks as well and that doesn't illuminate white sadly, everything must match!!
16th Apr 2016 11:06am |
