- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Riccarton
Drain it out immediately, fill with the correct stuff, bleed, then drain again and re-fill.
It won't cause a sudden failure but may have damaged the seals (pump & box) so keep an eye out for any leaks starting.
Good luck
14th Apr 2016 8:00am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
