Home > Technical > Brake fluid in PAS
Maarten
South Africa 2002 Defender 110 Td5 SW Alpine White
Brake fluid in PAS
Good morning all
Recently my hand brake light started flickering usually going downhill.I then,in a blonde moment,proceeded to add brake fluid but started to put about 50-80 ml in to the power steering reservoir instead of the brake res.[In the end I did top up the brake res].My question now is - do I have trouble on hand or need I to drain the PAS and refill or approach the bank manager?
Thanks to all
Maarten
Post #523795 14th Apr 2016 6:13am
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
Drain it out immediately, fill with the correct stuff, bleed, then drain again and re-fill.
It won't cause a sudden failure but may have damaged the seals (pump & box) so keep an eye out for any leaks starting.
Good luck Thumbs Up
Post #523818 14th Apr 2016 8:00am
