Home > Technical > Brakefluid and gearboxes
spudfan
Ireland
Had a talk with an "old" mechanic and he told me that in times gone by they used to cure leaking gearboxes and poor shifting gears by adding about an ounce or so of Dot 3 brakefluid to the gearbox. Anyone else heard of this? I wonder if it would be of any help to those with poor gear selection in Pumas or is it a no-no with modern gearboxes? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #522806 10th Apr 2016 4:48pm
shaggydog
I have heard of this, from what I can understand from the sage who told me its due to acidic nature of brake fluid causing the rubber seals to swell slightly.
Fix's the leak but not forever and once the seal relaxes a bit the leak is worse.
I have not used it as a fix as I work on the basis that the reason its leaking is the seal is worn out and needs to be replaced.
Up to you if you want to try it Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #522808 10th Apr 2016 4:53pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I have heard of this for P.A.S system but to gearboxes. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #522809 10th Apr 2016 4:53pm
spudfan
Ireland
It was new to me so I was just asking had anyone else heard of it. I am sure there are lots of "fixes" like this out there. I was a little surprised that it is not included in "Land Rover's Working in the Wild" manual as an emergency fix. Smile 1982 88" 2.25 diesel
Post #522818 10th Apr 2016 5:09pm
jimbob7
Doesn't saw dust have the same effect Whistle ?? Pov.spec,ftw. 2006, 110,TD5.
Post #522978 11th Apr 2016 10:26am
spudfan
Ireland
I have no idea. I don't even know if adding brake fluid works. That is why I asked the question. 1982 88" 2.25 diesel
Post #523011 11th Apr 2016 11:56am
In Oz I was once told to put a banana in a noisy rear diff to quieten it down.
Post #523014 11th Apr 2016 12:02pm
Bananas in diffs and gearboxes is an old trick, but only helps long enough to sell the vehicle and so a runner. It is not a viable long-term remedy!
Post #523069 11th Apr 2016 2:41pm
