Home > Maintenance & Modifications > New rear badge - what glue to use? |
dunc Member Since: 31 Dec 2015 Location: surrey Posts: 132 |
I have a new oval LR badge for the back of my 90. It has a flat polished aluminium surface. I would like to glue it on, not rivet. Does anyone know what glue to use with sufficient strength that it won't easily fall off, but with properties that will allow its removal in the future without leaving damaged paintwork?
I'm thinking an Evostick style rubber based glue? Does anyone have any ideas/experience on this? |
7th Apr 2016 8:49am |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Would you not be better using number plate tape?
http://www.halfords.com/motoring/paints-bo...pe-12mmx4m 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
7th Apr 2016 9:00am |
Same as Mikeh501 Sikaflex and rivets on my rear wheel swing away carrier security plate.
Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Apr 2016 9:18am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2102 |
And nice tiling to boot Mal!
Straight as a die. |
7th Apr 2016 6:00pm |
Thanks Screbble. OCD and being an electrician I used cable offcuts as tile spacers. If you go through life with your head in the sand....all people will see is an ar5e!!
8th Apr 2016 8:27am |
I was an electrician when I was alive and also have mild OCD....
That's probably why I noticed the high quality workmanship. I'd like to say that all electricians have an eye for detail and high standards but..... I do however think that electricians have the smartest looking Defenders......(with the exception of yours truly of course). |
8th Apr 2016 11:50am |
