![]() | Home > In Car Electronics > Evoque Torch |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 ![]() ![]() ![]() |
It's a Discovery one. Not sure what the actual difference is?
£90 inc VAT, not sure about postage. |
chrispy Member Since: 13 Mar 2015 Location: Gwent Posts: 347 ![]() ![]() ![]() |
I've already pm'd him about this. I'm in for a group buy as my wife's 90 is screaming out for one of these, although where to fit in a pre Puma?
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
^ how about front slant bit of cubby? My 109 thread
my youtube channel |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen Posts: 631 ![]() ![]() |
will set up a group buy tomorrow
![]() Send a paypal payment direct using this link www.paypal.me/duckworthparts www.duckworthparts.co.uk My Direct Line: 01673 849873 Email: danroberts@duckworthlandrover.co.uk Supplier of Genuine Land Rover & Jaguar Parts For All Models Can also supply OEM & Aftermarket parts ![]() |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
I believe someone mentioned the only difference is to do with the size/shape of the mounting unit... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
Wow,can't imagine the number of PROPER, QUALITY flashlights I can buy for £90!!!Shame it doesn't have "Landrover" stamped on it tho
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2769 ![]() ![]() |
Rechargeable with dock?
Only small rechargeable ones I found had separate cable with wall or 12v plug - not ideal. I think £90 odd is reasonably good value considering how quality & smart it looks. Each to their own though. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Group Buy is up; http://www.defender2.net/forum/topic42703.html
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
Smartwater it too, just in case it goes walkies.
Now that the group buy is going ahead, would someone that's feeling brave document the fitting process in the puma dash?
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
As soon as I receive mine, hopefully by Wednesday, I´ll let you know (with pictures) what its about.
Stephen 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
How is the fitting going?
Im waiting for a Dremel to start hacking at my dash... |
So I took the plunge..... and cut a massive hole in my dash!!!
![]() I masked off the panel where the torch would be installed and cut using the Dremel; ![]() Click image to enlarge I tried to block the little shavings of plastic from going down inside the dash but it was useless. In the end I just used the hover after to clean up the best I could. Next I sanded down the hole and made it all look neat, I also had to cut back the reinforcement behind the hole so the new metal reinforcing bracket would fit flush to the back of the dash; ![]() Click image to enlarge I glued in the new metal reinforcing bracket; ![]() Click image to enlarge Installed the torch; ![]() Click image to enlarge Wired it up using the supplied loom for now. The green charging light is flashing so it all seems to be working. ![]() |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Looks good, still need to do mine
